Thread: DRL's / boot leds
    May 2011
    heathrow
    Default DRL's / boot leds
    Hi just a quickie (ayeaye) would drl's work in front grills if wired into the side lights? would they flicker even though the sidelights are 501's and if i wired led strip into the boot would it flicker? if i wired them into the boot lights?
    Jay
    Aug 2010
    Stoke on Trent
    DRLs should be turned off when side lights are on.
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    See this post, this is what the previous owner did to my car.
    http://www.vectra-c.com/forum/showthread.php?t=102045
    LED strip won't flicker if wired to the boot lights, I did mine about a month ago. I just pulled the light out and then disconnected if from the connections, when you do this you should see a hole I just stripped back enough cable to feed though the hole and twist, when you plug the light back in it makes the connection tight. Job done took me about 10 mins.
    Regular Member mccluskey119's Avatar
    gourock
    I had drl units fitted to my fog covers, I thought they looked smart but the local traffic police demanded I turn my fogs off " I tryed to explain they are nit even showed them" but still had to take the wires out I really want them again as a few friends and cousin has the very same drls I have lol,
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by mccluskey119 View Post
    Fit a pot to the circuit to turn the light level down and a kill switch to turn them off.
    Gazza4
    gourock
    Whatever you said there gazz it sounds good haha I think if u get new ones ill give you a shout mate
    Paul
    May 2011
    heathrow
    cheers for the info guys, i had drl's on my 02TT and got pulled once but they were curious as to what they were. they even liked them but i want some merc style lights for my vec c and thought i would see if they would flicker. my TT had leds so didnt flicker but i dont want to fit them to find they strobe for a while after. which is the best way to wire drls in to stop the flicker, can they be done easily? jay
  1. Second boot light and leds
    By sriandy in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2012, 07:25
  2. fitted leds in boot (quick pics)
    By scottwales in forum Styling
    Last Post: 3rd July 2012, 22:31
  3. Changed my Boot LEDs...
    By davedrinks in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2012, 19:25
  4. boot light leds
    Last Post: 14th March 2011, 22:15
  5. Boot LEDs fitted...
    By davedrinks in forum ICE Gallery
    Last Post: 25th February 2011, 21:39
