Results 1 to 10 of 14
Thread: what oil is good or best for DTI
    Regular Member smirnoff sri-dti's Avatar
    Apr 2011
    London
    Default what oil is good or best for DTI
    I have 2.2 DTi sri and wish to ask you pips what kind of oil are you using for your DTi ?
    I got my vectra c about 2 months ago and last owner said he changed oil few thou miles ago with coma semi sent. oil
    I have checked everywhere that dti should run on FULLY Synthetic oil
    so I got From GSF shop 5 by 30 fully synthetic
    but when I changed it few guys told me that i should never go from SEMI to FULLY
    what do you pips think : is it OK to change from Semi to Fully oil ?
    what oil do you use in yours ?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Started using 10w40 semi on our DTi and it's running better/quieter. Was on GM 5w30 before.
    Full Member Big Sig's Avatar
    It would of had fully synth when it was new.
    Apr 2011
    London
    is it tru ?
    the Thicker the Oil --- More Harder engine works
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by smirnoff sri-dti View Post
    is it tru ?
    I had 5w50 in the 3.0CDTi and the mpg was the same as with the 5w30 or the 5w40 I'm using now.
    is it tru ?
    Yes the thicker the oil the more resistance it puts up but I doubt it's much. Not forgetting the viscosity changes with temperature.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Over the past 3 services i've tried 3 different oils and my latest change has been the best
    Firstly I used castrol's recommended 0w-30 edge and while it was ok the engine seemed quite loud and the oil far too expensive (pretty sure I was nearly 70 quid for it)
    Last year I switched to Mobil1 0w-40 supersynth and fuel economy was great but the engine got really noisy and there was a puff of blue smoke on start up. My theory was that as the oil was so thin when cold it was dropping past the valve stem seals as things cooled down. This resulted in the car consuming oil. The costing of the Mobil1 was alot cheaper at about 50 quid but the resulting problems made me decide to change again this year
    This year I switched to Castrols magnetec 5-30 (recommended for vx/opel) and it's turned out to be a great decision. The engine is alot quieter and smoother, the fuel consumption is still good and best of all the blue smoke on start up has gone.
    I bought mine from Asda and it was about £40 but B&Q have it on special offer at the moment
    Hope that helps
    Regular Member Adam8220's Avatar
    Apr 2011
    Ripley, Derbyshire
    i use the gm 5w-30 and quite happy with it although now and then i do get a puff of smoke at start up.
    Regular Member eaglepva's Avatar
    Up North
    I use titan super synthetic 5w/30 from unipart about £29 for 6litre. Its recomended for vauxhalls and pretty cheap.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    My 2.2 DTi has Castrol Edge 5/40 in it at the moment, nice and quiet.
  1. Maybe Good Things Do Happen To Good People....
    By Leemarksmith in forum General Chat
    Last Post: 16th October 2010, 22:12
  2. Cheap rear spoiler...too good to be any good?!
    By Lightboy in forum Styling
    Last Post: 26th February 2010, 23:03
  3. seems a good set up for a good price?
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2009, 09:31
  4. Some good news, and some not so good...
    By Penfold101 in forum The 'Off Topic' room
    Last Post: 19th August 2008, 10:06
  5. Good spec Signum, Good price too!
    By AndrewTi in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2007, 18:44
