Results 1 to 2 of 2
Thread: Advice on battery charging
    dudley
    Default Advice on battery charging
    I have a Maypole battery charger, like this one http://cgi.ebay.co.uk/Maypole-12v-an...item4158c5e279
    Due to starting problems I have taken my battery off the car to see if it needed a charge, I have set up the charger, on the lowest charge setting, and the battery read the following charge on the needle on switch on - 15amps, it moved to 0amps over a period of an hour.
    what does this starting figure mean, and how does it relate to battery charge on initial recharging..?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Typically that figure shows how much current is being fed to the battery ..... 15amps - almost flat battery..... through to 0amps - fully charged battery.
    The next question is how long the battery holds that charge ?
    If the battery is bad while in the car I would summise one of two possible problems:
    1) Battery knackered - not holding charge.
    2)Charging system fault - not charging battery
    Many places such as Kwik Fit, HiQ, etc will do a free battery test but I'd be leaning toward the battery being at fault.
  1. Battery charging advice needed please
    By ijk571 in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2012, 22:34
  2. Battery and charging etc....?
    By ronnie63 in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2012, 12:43
  3. battery not charging on signum
    By superjetandy in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2011, 17:01
  4. battery not charging on signum
    By superjetandy in forum Troubleshooting
    Last Post: 28th February 2011, 19:21
  5. Charging a battery
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 14:24
