Results 1 to 10 of 14
Thread: play in the steering wheel
    Regular Member Si-SRI's Avatar
    Oct 2009
    LINCOLNSHIRE
    Default play in the steering wheel
    Noticed today i have what can only be described as play in the steering wheel,
    Hard to describe rearly but i can wiggle the wheel without anything happening at the wheels,steering wheel sat dead straight ahead position?
    What will it be?
    Nov 2010
    doncaster
    just sounds like a bit of play in steering system dont worry ess its really excexxive turn wheel and wheels stay still lol
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    bolt lose in steering wheel??
    Oct 2009
    LINCOLNSHIRE
    Theres nothing untoward that sticks out so i'll play(no pun intended) by ear so to speak,
    Is there any uj's around the coloum etc i could look at or check?
    Sep 2010
    in a box
    i cant hepl on that mate but there will be one or two somewhere. where i do not know
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Quote Originally Posted by bangty 1 View Post
    Wouldn't matter if there was, the steering wheel has a locating notch on the shaft that matches the steering wheel so it wont move independently of the shaft.
    Sep 2010
    in a box
    did think this but was to late to delete
    Aug 2010
    Derbyshire
    Quote Originally Posted by Si-SRI View Post
    What will it be?
    This happened on mine and fixed it by tightening up the pinch bolt at the base of the steering column were it fastens on to the rack.
    You can access it under the bonnet behind the engine 12mm or 13mm socket if I remember rightly, hex socket best.
    Apparently they can work loose. Mine's an '06' Signum but should be the same on Vecs.
    Mick
    WGAF#5
    Quote Originally Posted by MickAP View Post
    Mick
    as above micks quite right these bolts do become loose and can cause advisories/Failures on MOT's
    staffordshire
    Agree with MickAP, my '06 Vec had the same issue and a simple tightening of the pinch bolt fixed the problem.
  1. Replies: 6
    Last Post: 13th March 2011, 10:47
  2. Steering Wheel Free-Play
    By freddy in forum Suspension, Wheels & Brakes
    Last Post: 14th December 2009, 16:42
  3. free play on steering wheel
    By andys964 in forum Suspension, Wheels & Brakes
    Last Post: 12th September 2009, 02:17
  4. Steering Wheel Play...
    By mdre83 in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2008, 15:07
  5. Play in steering
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2008, 10:26
vauxhall vectra play in steering wheel
steering wheel play on vauxhall signum
