Results 1 to 10 of 19
Thread: clutch replaced but now extreme banging!!
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default clutch replaced but now extreme banging!!
    Hi as above, ive had the clutch, pressure plate and hydraulic bearing done by a local garage but as i drove away have noticed very bad loud banging every tiny bump on road, like ive no shock absorbers! Or the front axels dropping off! I jus caught the garage guys who was closing up who told me to bring it straight back in morn and they will check it out. What does it sound like? Its makin me feel physically sick ive paid for this to my car! Although they told me not to worry and they will sort it.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    subframe not done up i bet
    Sep 2010
    Leeds
    Subframe bangty?? Wot does that entail?
    Sep 2010
    Leeds
    Anyone else? Im just trying to gather info, incase they carnt resolve.
    Sep 2010
    in a box
    its the thing that holds your wishbones and the like on holds the frount end really and you undo it to drop gearbox and you sed big bang that would bang bad if undone
    i fort i replyed but quess it didnt work lol
    Sep 2010
    Leeds
    So if its not tightened up properly, this wud cause front end havoc? Everytime theres a wave in the road or any un smooth road surface it sounds like wings are smashing off and axels on floor! Wud the noises be so bad if sub frame wasnt tight enough!?
    Sep 2010
    in a box
    just think all your wishbones arb bar all of that is bolted to the subframe and as you saying is a big bang this would do it it could be loads of things i bet like something lose knocking but subframe would be easy to miss id say as it looks tight when you look at it but there not could be loads of things mate really but i saying subframe as that lose will make a big clunk could even be a droplink gone arb buses gone anything
    is it over every little bump or just big ones??
    just thinking subframe as you had new clutch have to half undo drivers side and undo fully the pass side is why i say subframe
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    sounds like a likely suspect to me
    Sep 2010
    Leeds
    Yeah it sounds worse from passenger side but it is all accross front! And its over most bumps and waves in roads no matter how small! Thanks lads i hope it summet so simple that jus needs tightning up
    Sep 2010
    in a box
    well when you find out tomo let us now what they say.............but yer sounds like subframe as worse on pass the drivers could be wrong but hope gos well for ya
  1. Where to get the Clutch replaced?
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2012, 22:50
  2. Clutch and dmf replaced :)
    By nige87 in forum Engine & Drivetrain
    Last Post: 13th June 2012, 20:13
  3. 3.2 clutch slipping so being replaced, flywheel options?
    By merge in forum Engine & Drivetrain
    Last Post: 28th May 2011, 16:20
  4. Replies: 31
    Last Post: 18th January 2010, 18:12
  5. DMF + Clutch replaced, now loss of power
    By yzf1kr in forum Engine & Drivetrain
    Last Post: 28th July 2009, 21:07
