Thread: what is this called?
    Apr 2011
    essex
    confused what is this called?
    Ive been under my car and noticed something has been leaking its covered in black oil. im not sure what its called its the bearing thing i think. does it need to be sorted soon?
    thanks
    Apr 2011
    essex
    <a href="http://s1184.photobucket.com/albums/...t=SAM_0452.jpg" target="_blank"><img src="http://i1184.photobucket.com/albums/...1/SAM_0452.jpg" border="0" alt="Photobucket"></a>
    Regular Member DarylAAS's Avatar
    South Shields
    is that not the driveshaft?
    it certainly is daryl
    South Shields
    Woop... good guess lol... although dont know what or where the seal would go on there..
    when you remove the drive shaft from the gearbox , there is a removable seal that houses in the gearbox , once the shaft is out the seal takes about 5 mins to change if that
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    it's a fairly easy fix although it appears to be coming from the half shaft side meaning the driveshaft and the half shaft will both have to come out
    Regular Member djr69uk's Avatar
    Midlands
    assuming it isn't oil from elsewhere that has run down the side of the box and onto the shaft...
    probably not the case, but worth mentioning and chekcing.
    Apr 2011
    essex
    Quote Originally Posted by marktaylor View Post
    cheers every1 its off 2 the garage tomorrow to get it sorted. would this cause a rattle while driving at motorway speed?
    East Midlands
    In a word "No"
  1. Replies: 5
    Last Post: 22nd November 2011, 13:51
  2. What where they called
    By Ralphwells1967 in forum The 'Off Topic' room
    Last Post: 18th April 2011, 08:32
  3. What These Called ?
    By Tam80 in forum Bodywork & Interior
    Last Post: 26th February 2011, 23:21
  4. What's it called
    By Damian in forum General Chat
    Last Post: 12th January 2009, 00:36
  5. what is it called?
    By kenp in forum General Chat
    Last Post: 26th December 2008, 10:00
