Results 1 to 10 of 13
Thread: Bumper on SRI 2008 Not fitted correctly
    Regular Member 150_SRI's Avatar
    Sep 2010
    Lincs
    Default Bumper on SRI 2008 Not fitted correctly
    Hi All,
    My bumper was recently removed to access a fog light, the bumper has been fitted back to the car, but is not fitted right on the passenger side.
    Please see pics below, it is sitting about 2mm away from where it should be:
    Sep 2010
    Lincs
    I then pulled the bumper out slightly and see a slot where i think the bumper should be hooked onto the car, does anyone know how to fit this correctly or know what should go in the slot that is highlighted in red on the picture beneath?
    Regular Member djr69uk's Avatar
    Midlands
    mine does that. i just ignore it now
    Sep 2010
    Lincs
    I think what needs to be done is that once the bumper is fitted, like now, we need to put our arm up underneath and put some sort of plastic through the slot highlighted in red, which should go through a slot on inside of the wing, this should ensure bumper is pulled in tight...
    Not sure if this is how the bumper is supposed to be connected, but just my idea from looking at this slot.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    looks like the bumper clip has gone under the body clip.. try lifting the bumper as you put it back in.
    Regular Member mann3210's Avatar
    scotland, perth
    remove the torx scres @ the end of the bumper corner (in the wing liner) there is an adjustable bumper bracket @ the end of the wing make sure thats pushed forward push the bumper onto it then tighten the torx screws back up, the screws pull the bumper into place
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by mann3210 View Post
    although it may be that the lugs on the bumper have been damaged at some point
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    I sometimes just fold it in a bit at the corners by hand before refitting it just to give it that bit of extra fit.
    scotland, perth
    yeah or that lol
    Sep 2010
    Lincs
    Ok great, are these the 2 x Torx 25 screws in the wheel arch liner?
    I removed these earlier and pulled the liner to one side but couldnt get much access to that far in the wing as its right near the headlight. Had the wheel on opposite lock but was still very tight. Does the bumper need to come off again or can this just be adjusted by removing wheel arch liner? cheers
  1. 2008 sri front bumper
    By tony watson in forum Styling
    Last Post: 26th January 2011, 17:16
  2. Vectra SRI 150 diesel XP 2008 with VXR bumper
    By ROY2593 in forum Cars for sale
    Last Post: 22nd March 2009, 23:44
  3. Has my cambelt been fitted correctly?
    Last Post: 5th February 2009, 11:20
  4. 2008 XP1 SRI complete front bumper in star silver
    By ROY2593 in forum Parts for sale
    Last Post: 6th January 2009, 19:31
