Results 1 to 10 of 26
Thread: Rear wiper jet issue
    Kent
    Default Rear wiper jet issue
    Hi
    Having a problem with the rear washer jet in the fact that it doesnt work, I assume it's the same pump for the front wipers as the back, the front works fine.
    I've put s small pin into the hole of the jet to clear any blockage but it didn't go in very far, wondering if there is a blockage in the pipe somewhere. How would I remove the wiper jet from the roof to inspect and clean out? If I need to remove the roof lining how would I do that?
    Kent
    Maybe I should have put it's a 04 2.2 dti vectra
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    you could try cleaning out the filter in the washer bottle fella if not proberly will be the washer motor
    Sep 2009
    Glasgow
    im sure when i had the same problem, i thought the car only had one pump, but the garage said they had replaced the rear pump and all was good ?
    Barrow In Furness, Cumbria
    Do you have enough water in the washers? I think that if there isn't a certain amount then the rear one won't work, only the fronts.
    Regular Member vectradave57's Avatar
    Apr 2011
    Lincoln
    Quote Originally Posted by Chris SRi View Post
    Kent
    Thanks, yes there is plenty of water in there, when you try the back washer jet the front jets 'dribble' slightly.
    Could anyone confirm if there is one or two pumps please?
    Regular Member Whisky's Avatar
    Mar 2011
    Kirkcaldy/Barrow-in-Furness
    Sounds like a blockage somewhere, I think we've all had the same problem at one point during the winter,but now,i'd defo say a blockage.
    Are you VXR Enough
    13 Post(s)
    its only one pump fella just that it has 2 outlets make sure the filter in the washer tank is clear and try a new washer jet
    Kent
    still havent got round to doing this yet, but I went and had another look this morning while sorting something else out, topped water right up in the bottle, wiggles a pin in the jet hole and tried it, squirted a small amount out then nothing.
    I couldnt find the filter in the bottle how do I clean this is it underneath?
    Front jets still working
  1. Front Wiper Issue
    By gregac in forum Vectra C / Signum Troubleshooting
    Last Post: 10th December 2012, 14:02
  2. Wiper Issue
    By dazmufc in forum Bodywork & Interior
    Last Post: 8th June 2012, 12:41
  3. wiper issue
    By jimmywhu in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2012, 21:43
  4. Different from the normal wiper issue
    By Jebus in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2012, 22:07
  5. Another front wiper issue
    By Nato in forum Bodywork & Interior
    Last Post: 1st February 2012, 22:13
