Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Injectors?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Default Injectors?
    Having owned my V6 CDTI Signum for 4 months, the problems are starting to rear their ugly heads. I've been reading through threads but nothing seems to cover it exactly.
    I'm getting some enging vibration between idle and 1700 revs almost like a misfire but not as bad. i.e. cylinder still firing but maybe not quite right. I've had a slight lumpy idle for a while. It appears to go when under load though for example when holding on the biting point.
    At high revs i'm getting black smoke at high revs, 3000+. Not major and not all the time.
    I've been using redexx since i got it to try and clean the fuel system but i'm shamed to say I ran the tank VERY low last week. Think it might have something to do with it?
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Might be worth pressure testing the cylinders, could be piston rings worn slightly.
    I assume you've already done the obvious, full service etc?
    South Central England
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Do they have swirl valves?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Not had a service mate. Had one just before i got it. Oil was crystal clear.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by nutron View Post
    Not the prefacelift mate.
    I got new injectors fitted in February and I'm still getting an occasional judder lower in the rev range, but only under slight load and only in a high gear. I too am getting smoke, only grey-ish, not always though.
    Stoke on Trent
    My V6 CDTi smokes when you rev its nuts off... and I have a judder from 1000- 1500 rpm when under load, I can hear an injector knocking on idle, but its not reducing performance too badly ... I've learned to ignore it!
    Does sound like an injector though - have you have a leak-off test done?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by smitd004 View Post
    What does the leak off test involve?
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The juder my be the DMF I guess. Smoke may be coming from worn turbo bearings.
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Even though the EML light ahsn't come on there still may be a code registered, my facelift V6 had missfire on cylinder 1 logged but only threw the light on twice in 6 weeks or so.
    Try and get them read after the lumpy idle but BEFORE the key is removed.
    Stoke on Trent
    Basically, a leak off test determines if any excess diesel is 'leaking off' from the injector.
    Not all fuel that is fed to the injector is used in combustion, and will be fed back into the fuel tank - via the leak off pipes on the top of each injector.
    If an injector is sticking open, or is performing poorly, it will leak off excessively.
    My local diesel specialist charged an hours labour for the test.
  1. injectors
    By sandy13 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st January 2012, 11:08
  2. 2.0t injectors
    By mann3210 in forum General Motoring Chat
    Last Post: 1st January 2012, 15:27
  3. injectors
    By damo-SRI-T in forum Petrol Engine related
    Last Post: 9th June 2011, 08:02
  4. Injectors? help
    By Ean in forum The 'Off Topic' room
    Last Post: 26th October 2009, 12:56
  5. Injectors
    By andymagee1982 in forum Engine & Drivetrain
    Last Post: 8th November 2008, 20:24
