Thanks Thanks:  1
Likes Likes:  1
Results 1 to 10 of 29
Thread: P1105 & P0105 Barometric Pressure not plausible
    Regular Member Innes's Avatar
    Plymouth
    Default P1105 & P0105 Barometric Pressure not plausible
    Hi guys,
    when I was in a slow moving jam I noticed the spanner thru car icon appear then disappear. Thought nothing of it but would keep an eye open for it. It happend aagain today as I pulled up to a set of lights it came on again but this time stayed on for a half a mile in Limp Home Mode then went out again. Just pluegged in the reader and got:
    P1105 - Barometric Pressure not plausible with Boost Pressure
    (FA) - Not present
    P0105 - Barometric Pressure not plausible with Boost Pressure
    (FA) - Not present
    Is the Barometric Pressure at the top left of the engine bay by the MAF? I've had a look at it and it looks clean and its connected.
    I cleaned the boost sensor about 3 months ago so cant imagine it needs it again already.
    Has anyone got any other suggestions?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Could be split hoses mate or boost sensor sure ive seen them codes before might be best searching forum as im sure someone posted about Barometric fault codes a while ago
    Irmscher Insignia CDTI 130
    West
    I'd start with cleaning the map/boost sensor & the inlet elbow too
    CO.Durham
    i had this the other week mate i found it was a tiny tiny hole a vacuum joint i replaced all the rubber joints been fine ever since.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Our 2.2DTi sometimes, and very randomly, goes into limp mode giving these codes. No idea what it is. As far as I can tell, vacuum hoses are in perfect shape, as are the boost ones. Boost sensor, EGR, top manifold are all sparkling clean.
    CO.Durham
    i thought mine where all ok, i dont have a vacuum tester so my bro pressure tested them and the one to the actuator had small leak could not hear it just pressure went down so replaced them all in one go. i put mine in 3 garages and had a few different responses some said throttle position sensor boost sensor and my local said one pipe will have a hole in i was on hours trying to find and i could not find it so i thought id cable tie the actuator open and bingo solved prob, thats when bro tested pipes.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Did you have a bit less power than usual?
    CO.Durham
    Did not seam like it, I had not had the car long and 2.0 dti standard does not have much power to start with. It seamed when car was about 2 .5 thou revs it went into limpode but on odd occasions it would go in early or sometimes I was lucky and it never went into limpmode.
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I have seen that fault code when tuning up the boost with the CRD-T tuning box. The ECU is seeing less pressure than is actually present, so it's quite reasonable in this case. If you are getting it without modifying the boost sensor readings, then I would check:
    Boost sensor on the manifold (also a temp sensor)
    MAF sensor
    These you have checked already, so the next step is to look for boost leaks. Split hoses are common, the U tubes onto the intercooler being the No1 offender. Clips not tight could cause leaking. The swirl valves can start to move vertically and leak boost. The intercooler could be ruptured, which would be hard to check without removing the heat exchanger.
    Plymouth
    Vacuum pipes are in good nick they are the silicone ones. My Inter cooler hoses have also been replaced with silicone ones although the one on the right going into the manifold is home made so will check how firmly its in place. I havent check the U shaped ones connected to the intercooler yet though.
    Cleaned the boost sensor this afternoon just in case.
    Will keep an eye on it for now. its only happend twice. Once very briefly and the other for half a mile. It happens when I'm near stationery o.e rolling up to the lights or slow moving Jam.
    Thanks for all your input. Will keep you posted!
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. Barometric Pressure Sensor - P0105
    By Chris B in forum Engine & Drivetrain
    Last Post: 5th June 2012, 18:50
  3. p1105 Barometric Pressure Sensor problem
    By stuarty1 in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2012, 08:34
  4. P1105 barometric pressure not plausible with boost
    By ian mc in forum Engine & Drivetrain
    Last Post: 14th November 2010, 11:49
  5. P1105 and P0105 Help?
    By vectra2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2008, 00:30
p1105 opel
p1105
barometric pressure not plausible with boost pressure
https:www.vectra-c.comforumshowthread.php137922-P1105-amp-P0105-Barometric-Pressure-not-plausible
p1105 opel vectra c
p0105 opel
Opel DTC P1105-a
p1105 vauxhall vectra
p0105 vectra
Opel DTC P0105-52
Opel DTC P1105-fa
Opel P1105(FA)
Vauxhall DTC P1105-A
Opel P0105
Opel DTC P0105-A
Opel DTC P0105-COpel DTC P0105-FAVauxhall P1105p0105 опелp0105 vectra 2.2 dtip0105 zafirap0105zafira p0105 p1105p1105 opel zafiraVauxhall signum fault code p1105
