Thread: Heavy smoke on start up-random
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Heavy smoke on start up-random
    Hi all,
    I have a bit of a random issue.
    Over the last month or so I have had the following issue happen twice.
    Start the car first thing in the morning and I get clouds of blue/white smoke and idle is a bit lumpy. It continues to smoke when ever I stop in traffic eventually it seems to get better once the car is warm.
    We have had it on opcom and no faults showing and no lights on dash but this was after the fault had rectified and all was running normally. The injectors where within tolerance and nothing else seemed unusal.
    At no point have any dash lights come on, the car is not using water/oil and the mpg is showing 49 mpg which is normal.
    For ref:
    Precat has been replaced with a straight through pipe
    Cat Removed
    Hybrid Turbo
    BSR Remap (been on for 3 years at least)
    K and N filter
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Turbo oil seals - is it a new Turbo?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by AntSSSS View Post
    Turbo is only a few months old. It was Hybridised by AET Engineering.
    Seems to only smoke at idle not under stress
    Full Member Big Sig's Avatar
    Quote Originally Posted by merikiito View Post
    It would also be using oil if it was the turbo. Maybe valve stem oil seals? (would still be using oil)
    The only time I have had a turbo oil seals go it would only smoke when slowing down as the vacuum caused by the engine as it slowed down (say in gear, stopping for a junction) would suck the oil through the seals and into the engine producing blue smoke.
    Maybe whip the hoses off and have a look for oil in the boost pipes?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    Hi all,
    For ref:
    Cat Removed
    Hybrid Turbo
    K and N filter
    what caused your blue smoke? did you find out
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I put it down to poor fuel in the end. I always fill the tank to the brim due to the miles I do and I think it eventually flushed it out.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    do you think its down to certain petrol stations then
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by vectra ste View Post
    I have always filled up with supermarket fuel with all my cars and this is the first issue I have had with fuel. I still cannot prove it was the fuel as the issue has never come back (touch wood)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I think I would be inclined to empty the tank and change the fuel filter if it happened again
    I use whichever supermaket fuel I am passing when I need to fill up. I would say that 50% of the time it is Tesco
    Full Member
    Nov 2009
    Warrington
    my car has always had this on start up (vec 1.9cdti 150) fair bit of blue smoke when first start the car, never found out why but oil levels have always been ok.
  1. Occasional Heavy Blue Smoke (150 CDTI)
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 18th September 2012, 12:52
  2. Car start to present day! VERY VERY pic heavy
    By paul_sri150 in forum Quick Photo Album
    Last Post: 21st June 2011, 08:20
  3. Start to Finish - heavy pic
    By Wolflinn in forum Styling
    Last Post: 21st February 2011, 17:43
  4. black soot/smoke under heavy load
    By paul_sri150 in forum Diesel Engine related
    Last Post: 4th August 2010, 13:29
  5. Smoke on start up! What do you think?
    By DG01 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2008, 22:58
heavy start vectra c
