Thread: 2.2 dti timing chain guides
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Default 2.2 dti timing chain guides
    has any changed theirs if so how hard is it , i think mines need changed im getting an awful rattling at that side ,can you tell if they are woren by looking at them
    New Member andy treg's Avatar
    Apr 2011
    accrington
    think mine needs doin aswell ive heard that many bad things about getting them changed about probs after ive been put off , then i went to vauxhall and they want £850 to change them so the job is on hold lol , is it at around and above 2250 rpms ? u cant look at them u have to split the block !!!
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    that must be for a full timing chain , tensioners and guides the guides are £12 + vat each ffrom vauxhall im thinking of changing the upper guide it looks like you just take the rocker cover off and remove the guide bolts on the side of the chain cover
    Nottinghamshire
    There is no need to remove any engine covers to replace the chain tensioners, except possibly the engine undertray for access to the lower one.
    You just undo the hex bolt and slide the chain tensioner out noting which way it fits, making sure not to loose the gasket.
    To replace, insert the new tensioner (making sure it's the right way around), replace the gasket, and then the bolt which is tightened to 60 Nm.
    Replacing the timing chain guide rail is a lot more involved and does involve taking various covers off of the engine.
  1. timing chain?
    By adammarc in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2011, 19:54
  2. timing chain
    By barneyp06 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 11:04
  3. timing chain
    By stuartbat in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2009, 17:38
  4. timing chain
    By ddd in forum Engine & Drivetrain
    Last Post: 25th July 2008, 21:10
  5. timing chain
    By dezzie in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2007, 22:05
vectra 2.2 tdi timing
vauxhall 2.2 dti timing chain
