Thread: Door handle loose
    May 2011
    Bangor, Northern Ireland
    Default Door handle loose
    Just bought an 03 elegance and have noticed that the rear passenger door handle is a bit loose, and does not return fully after being pulled.
    Is it a new handle required or can the mechanism be tightened / adjusted?
    Dunstable
    When you open the door, look above the lock mechanism, there is a grommet covering a torx screw. Take it off, pull the handle to the open position and undo the screw fully. It won't come out, but I believe it needs to be undone. That's the first thing I'd check.
    May 2011
    Ok thanks for that will have a look and see
    May 2011
    Tried that this morning but when I loosened the nut completely, the handle would not go back in at all lol
    May 2011
    Thanks for that.
    Is it likely taking the handle out and then putting it back in will tighten it up ?
  1. LED door handle mod ( outside )
    By bobsimes in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2012, 13:30
  2. changing O/S/R door handle
    By Steven T Davies-Moss in forum Bodywork & Interior
    Last Post: 2nd August 2011, 12:02
  3. help with door handle
    By shoota70 in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 14:46
  4. OSR External Door Handle & OSF Door Lock
    Last Post: 29th May 2009, 17:14
  5. door handle
    By decks in forum Bodywork & Interior
    Last Post: 17th June 2008, 12:05
vauxhall vectra door handle not working
vauxhall door handle tighten
vectra c slack door handle
vectra c door handle not working
