Results 1 to 3 of 3
Thread: Fitting an XP kit to an Estate with parking sensors...
    Regular Member bigSoft's Avatar
    Reading
    Default Fitting an XP kit to an Estate with parking sensors...
    I have an Elite Estate which has parking sensors as standard and on the Vauxhall Accessories site they list the "Rear Lower Skirt" as not being suitable for cars with parking sensors. I have seen plenty of pictures of Estates with the XP kit and parking sensors (many of them on this site) however I am not sure if these were fitted as standard or as an aftermarket add on.
    Has anyone here fitted an XP kit to an Estate that had parking sensors? If so was there any special way to do it or do I need to try and locate a different spoiler or use a different part number?
    Thanks for the help.
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    My old car was an SRI NAV XP estate (57 plate) and i ordered that new with the parking sensors front and back so they do make an XP valance for the estates, You just need the correct part number..
    EDIT: Found this pic, may be of use to you, If not Vectralicker has that car now, Im Chris will help you out if you need more/better pics
    Reading
    Thanks, I had a chat with a dealer who sells the parts and he hasn't found a separate part designed specifically for cars with park sensors from standard, however he does have the VXR lower spoiler for an Estate (part #93199105).
    It appears that when it gets fitted I need to get the parking sensors relocated into the new spoiler that sits over the existing parts and then colour coded, so that should be interesting. There are a couple of other chaps on here looking at kits for their Estates and they may have the same questions so between we'll get the right answer ;-)
    If it turns out there is a specific part then that would be great, otherwise it'll be interesting to see what the ordered part looks like (I wonder if it will have guidance holes for the sensors like a lot of bumpers seem to have?).
    In any case I'm sure there's a solution to be had.
  1. Fitting parking sensors
    By jammy_c in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2012, 18:48
  2. Estate Parking Sensors.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2010, 21:05
  3. Tip for fitting Parking sensors to an estate
    By 1973AJH in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2009, 10:06
  4. Parking sensors? Fitting question...
    By Craig1985 in forum Bodywork & Interior
    Last Post: 17th October 2008, 07:59
  5. Estate Parking Sensors
    By jbegbie in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2007, 20:14
fitting xp kit on vectra c
vectra estate parking sensor installation
