Thread: RUST SPOT-best way to remove please!??!?!
    Birmingham
    Default RUST SPOT-best way to remove please!??!?!
    Folks,
    My Vec-B has a nasty rust spot on the drivers back door, its about the size of a 50p piece on the bottom of the door.
    Whats the best way to treat this and to get rid as much as possible without having to paint the entire bottom half of the door?
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Anyone??
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Craig1985's Avatar
    harwich essex
    Ask a ford forum, common problem for them lol.
    Sorry I couldn't help
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I would scrape away the surface rust/are,gently, and sand it flat. Immediatly apply a coat of rust inhibitor which chemically converts the rust into a stable state and either leave or finish however is suitable.
    New Member Tmd's Avatar
    May 2011
    UK
    A continuation from nikroc
    Sand down the area and a little all the way around to bright metal if possible, then wipe with a degreaser or brake cleaner and dry. Then paint on some rust inhibitor paint -Kurust or whatever. Once dry mask off area around car and spray with light coats of primer - lightly sand bewteen each coat with fine wet & dry paper. Give it several coats of top coat paint, again light sand with fine wet & dry then clear laquer over top. For a DIY "on the drive" job that will sort it out.
  1. Rust contamination?
    By madman in forum Detailing and Car Care Discussion
    Last Post: 27th February 2012, 10:22
  2. Rust?
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2011, 21:38
  3. Need some help with rust.
    By Vaux-Man-G in forum Bodywork & Interior
    Last Post: 17th March 2011, 14:40
  4. Do you have any rust showing
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 19:03
  5. Rust!
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2007, 14:30
