Thread: Turning Over, But Ages To Start.
    Lincs
    Default Turning Over, But Ages To Start.
    Hi,
    Had a little issue this morning i've not had before. (1.8 petrol 2005, 99k). Started this morning, then cut out in seconds. Turning the key and the engine just kept turning. Tried several times, the last time i kept it on the key for about 15-20 seconds and then she fired up. Tried it twice since and it's been ok. Any common problem to look at here please?
    Paul.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    When was the car last serviced? Might be spark plugs or the fuel filter.
    Lincs
    Quote Originally Posted by cont1204 View Post
    2 weeks/2000 miles ago mate.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Hmm, next thing might be the coilpack on the way out. Do you know anyone else with a 1.8 you could swap with to try?
    north east
    another option is crank shaft senor but your probably going to ave to wait for a error code to find out.
    you can test the crank sensor by unpluggingit and the ecu will use thecam sensors instead, if its the same ith the crank unplugged lug it back in and try with cam sensor unplugged, if still the sme its neither of them.
    Lincs
    Thanks for those tips. It, fingers crossed, hasn't done it again.
    Sep 2010
    doncaster
    hi,
    I had a similer problem with my diesel vectra, it was and injector seal leaking..
    Jezz
  1. Old not new but been ages
    By Jatie in forum Introduce yourself.
    Last Post: 12th November 2011, 18:40
  2. Best Reg. No. i've seen in ages !
    By FIL 4822 in forum General Chat
    Last Post: 8th January 2010, 16:34
  3. Car took ages to start this morning?
    By PeterVV in forum General Chat
    Last Post: 20th December 2009, 21:19
  4. Car went in big puddled and stalled and wouldnt start for ages
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 18th July 2009, 00:14
  5. Should have done this ages ago.
    By Voxer in forum Quick Photo Album
    Last Post: 1st June 2009, 10:27
