Results 1 to 7 of 7
Thread: Boot lid issue on Vectra C 04 Estate
    May 2011
    Sharptown
    Default Boot lid issue on Vectra C 04 Estate
    Hi there
    Greetings from Norway, been a reader for a couple of months, and love the forum, especially the styling section. Didn't know a "old mans car" could get as nice as what you've got in here. =).
    Now, i have a problem with my boot lock, a couple of weeks ago it suddenly became a litlle "troubleish", it would unlock when i pressed the rear button several times, noe system in the counting or anything, it could unlock at the 3'rd time or the 20'th time. But now, it wil not unlock at all. The strangest thing, is that when i have locked my car, and it has been locked for a while, lets say, from 10 minutes to over the night, when i then unlock the car via my car-key sentral lock, the boot lid opens halfway, i cannot open the rear lid/door at all, but the lights in the trunk goes on, and i try to press the unlock button at the door several times but no go. So i have to push the lid back in, in lock state. I have checked the fuses, and can't find any relevant for exactly that kind of issue.
    Seems like there is a electrical problem regarding the button on the rear lid/door, any one experienced the same problem? And got a solution?
    thanks in advance guys and girls =)
    Best regards
    Autoboza
    May 2011
    Sharptown
    Bumping myself with a question, is there a manual way to open the boot on my estate?
    Can't find anything on the "wall" behind the boot door.....
    Thanks in advance.
    Regular Member kenp's Avatar
    Feb 2008
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    yes you can.. on the lower part from the inside, you can see a round "plate" made out of platick.. remove that, then with the little clever think where you fuelfiller cap can be place, that bit can be inserted and twited to manualy open the boot.
    Do you have power tailgate? (electric open close?)
    Because the closing then could be the Potentiometer or simply need to lubricate the wire.
    About the openning.. try replate the handel...
    May 2011
    Sharptown
    Quote Originally Posted by kenp View Post
    That green little thing?..Which hangs on the petrol door/lock?
    Not sure what you mean, the button/handler is electric, but its not a selfclose automatic door opener/closer like in expensive models...
    Try to open it manually first, then see, thanks for the tips! Appreciate it.!
    Mar 2009
    CO.Durham
    Had a little bother with mine, turned out rubber had worn and was not pressing the micro switch. Just added some tape to the back of the rubber button and repositioned the micro switch.
    Mar 2009
    Essex
    Had the same on mine and it was the solenoid in the catch, sometimes wouldnt allow to open, other times it wouldnt close!
    Replaced the boot catch for £40 from the dealer and all has been fine since!
    Feb 2008
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Quote Originally Posted by autoboza View Post
    well its gray on mine.. but yes..
    ahh so you dont "press" a button to close the tailgate..
    No problem..
  1. Electric estate boot issue
    By dreams3577 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 08:30
  2. Vectra C 2005 Estate with boot that wont open
    By skip85 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th February 2010, 10:33
