Results 1 to 10 of 14
Thread: Vectra C, facelift... 2.2 direct engine.... opinions?
    Regular Member Deann's Avatar
    Mar 2011
    England
    Default Vectra C, facelift... 2.2 direct engine.... opinions?
    For anyone who ahs, or has owned a vectra with this engine... how do you rate in? With regards to reliability, MPG, performance?
    I'm compaing this car to a 1.8 VVTI?
    Regular Member Knuckle's Avatar
    South
    MPG - very good, lowest i see is 36, highest 50 on a motorway run with air con!
    Reliability seems ok, mine has a few little things like when i accelerate from too low down i get a squeaky noise that i cant figure out, sounds like a belt perhaps.
    Doesnt burn any oil.
    Performance is pretty reasonable for a big heavy car, its a hell of a lot better than the 1.8 vvti i test drove before hand (5 speed).
    Mine is a 2006 55 Facelift SRI Direct on 92k
    Jan 2010
    glasgow
    good engines if there serviced rite and reg oil changes just make sure the fpr has been changed and the pump isnt the older 1 of and depending on the miles make sure if its hi ish its had the belt etc done first start up listen for a rattle if so it hi on pos the full belt kit will need done
    Mar 2011
    England
    Quote Originally Posted by hoochydady View Post
    What is the FPR?
    And what is the new one/old one with regards to pump? What should I look for/quiz the seller on?
    11 Post(s)
    Quote Originally Posted by Deann View Post
    What is the FPR??
    Fuel Pump Regulator.
    11 Post(s)
    Replace the word belt with chain.
    Jan 2010
    glasgow
    lol yip cheers for pointing that out dave my bad to many forums open at the 1 time < lol as said mate the fuel pressure regulator and hi pressure fuel pump to be honest you may be lucky and not need them doing just make sure it isnt rattling on start up first start up is the best time to listen as the first sign of the chain needing replaced make sure its had regular oil changes the more the better for this engine make sure no missfires etc most got the fpr done on a recall dont let that put you off mate there good engines even if you need to change the pump and fpr if your good at diy and spanners you could prob do it your self
    Oct 2006
    southampton
    15 Post(s)
    I have one, lovely engines if looked after, few common faults but if I had the info I have now I would have got the 2.0T HTH
    Jul 2009
    manchester
    Very smooth quiet engine with decent acceleration and economy my 58 plate averages 33 - 34 mpg on 50-50 urban /motorway has just had fpr replaced under warranty only done 11500 miles on clock dealer reckoned it had been overlooked on the recall.
    Blantyre
    Same here, I have had one, fuel reg and HPFP replaced to, snapped spring , and good MPG, cant complain though, this site makes you hear things that arent really there apparently............ so the Mrs tells me
  1. Replies: 35
    Last Post: 5th May 2012, 15:32
  2. Oil and filter change Vectra 2.2 direct and noise from engine ??
    By jkspoff in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2011, 17:09
  3. Replies: 2
    Last Post: 2nd April 2008, 18:34
  4. Opinions on the new 1.8 vvt engine
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2007, 01:59
vectra 2.2 sri direct opinions
vectra c 2.2 direct opinions
