Thread: CD70 and Aux in
    Engine : 1.9 CDTi
    Default CD70 and Aux in
    Just been playing with the settings on my 05 full can CD70 and in the audio menu where you can adjust the SVC and TA etc there is an option to set the AUX input.
    Does that mean my CD70 has the parts inside so I can just add the jack plug?
    I dont remember seeing a Aux setting anywhere else (Ie to select that as the source).
    Engine : 1.9 CDTi
    Anyone know?
    Aug 2010
    Stoke on Trent
    If the CD70 is factory fitted then no (too old). If however you or a previous owner upgraded to a CD70 then its possible. Remove it and look om the top... what date was it made and who made it..? I think it was fitted as standard from about 2007.
    Also try selecting Aux in and turning the volume right up. On mine when I did this before fitting the extra components for the aux in mod it used to 'tick'... after the aux in mod there was silence...
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    if you've used the cd70 update disc, then that option will show even for older units.
    If you do have an older unit you'll need the hardware mod.
    Regular Member SRI Alex's Avatar
    Telford
    Hi all,
    Might sound like a stupid question but im selling a 2005 CD70 Navi on ebay and iv had two questions that im struggling to find answers for so wondered if anyone here would know...
    Does the CD70 Navi fom a Vectra C fit in a 2007 Meriva or antara ?
    Apparently it was an option in the Meriva but not sure if that means it will fit.
    Aug 2010
    Stoke on Trent
    Quote Originally Posted by SRI Alex View Post
    Hi all,
    Like the Astra it may fit but not look quite right... The Astra CD70 has a different front than the vectra CD70 as the Astra has a vertical crease down the center to fit with the interior trim styling... this may be the same for the Meriva or Antara... sorry I don't have a definitive answer for you...
    Telford
    Quote Originally Posted by jimbojetset View Post
    Ahh right thanks for that, ill just have to say that it may or may not fit then they can make the choice to buy or not
    Engine : 1.9 CDTi
    Will take the stereo out later and have a look.
    I think I looked at the hardware or software version on the screen once and it was 2004.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    Quote Originally Posted by lofty View Post
    where can this update disc be found
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    From VX but you'll still need the hardware of the stereo modded
  1. Cd70 please help!!! :)
    By jones5n in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2011, 10:34
  2. Cd70
    By gregc in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2010, 02:32
  3. cd70
    By wstwatson in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2009, 20:51
2005 cd70 and aux
