Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: 1.9 CDTI 120 Hesitation Judder.
    Regular Member CDTI120SXI's Avatar
    Mar 2011
    Wrexham
    Default 1.9 CDTI 120 Hesitation Judder.
    At the end of my tether with this car.
    80k on the clock.
    Cruising along at 1500-2500rpm ish keeping a constant speed, when i accelerate the car seems to slow for a brief second and then pick up.
    I've read up loads of topics here about all the possible causes but there are no definite fixes and i don't want to star throwing money at it for things it doesn't need.
    Would anyone be kind enough to share how they fixed their's?
    EGR valve is new ive checked what i think are the boost pipes
    What other cheap things to do? and are there any guides how to do them on the 120?
    Thanks in Advanced
    West
    check around the vac system for splits etc & try a shot of fuel system cleaner followed by a good thrapping
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    When I replaced my EGR I was told that I needed a software upgrade (at vauxhall) as the new EGR's function slightly differently. There is a field remedy issued covering this. Will see if I can find the post about it, but on phone at minute. Not completely sorted mine but it is no where near as bad as it was when I first got it running ;-)
    If you bear with me I'll see if I can find the post about the remedy. hopefully that may point you in the right direction
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Year : 55
    Mileage : 92,000
    Here you go chap:-
    http://www.vectra-c.com/forum/showthread.php?t=118113
    I still get a bit of surging when at medium throttle (you can hear the EGR open/close, almost fluttering open and closed in quick succession) which causes the car to hesitate/jerk
    Hope that may help you out
    Already replaced:-
    Alternator,
    Woodbridge
    Cheers for the link, I have this problem, however it has only just started doing it. How can a software update fix it???
    Year : 55
    Mileage : 92,000
    I honestly have no clue Ginge lol.
    As previously mentioned though, its not completley sorted out the surging/jerking but has made quite an improvement from how it was when the EGR was first installed
    Already replaced:-
    Alternator,
    Motherwell Scotland
    You could try cleaning the boost sensor, this can cause the problems your having.
    Mar 2011
    Wrexham
    check vac system I'm going to take the pipes off make sure they are properly sealed. Cheers
    Quote Originally Posted by Damo77 View Post
    Here you go chap:-
    It was serviced at vauxhall 2k miles ago ill take it back make sure the newest software is on. Thanks
    Quote Originally Posted by st2malo View Post
    Gunna go whip that off now its at the back of the block?
    Aug 2007
    North West
    Trim : SRI With a few added extras
    Engine : 1.9 CDTI 120
    Year : 06
    Quote Originally Posted by CDTI120SXI View Post
    yep, right behind the EGR valve, iirc but in the middle at the back.
    Mar 2011
    Wrexham
    Quote Originally Posted by phil-h View Post
    found it, hanks need egr valve needs to come off unless i fine some sort of stubby torx key. might aswell check the EGR valve is clean.
  1. Legendary Judder/Hesitation!
    By wotsthestory in forum Y & Z30DT Specific
    Last Post: 24th July 2012, 07:28
  2. Engine/turbo judder/hesitation
    By kangakev in forum Engine & Drivetrain
    Last Post: 26th September 2011, 18:15
  3. Replies: 0
    Last Post: 8th August 2011, 16:39
  4. Slight hesitation/judder when accelerating 1.8 petrol
    By waterbourne in forum Engine & Drivetrain
    Last Post: 19th January 2011, 00:44
  5. 3.0 CDTI Hesitation and EML
    By sb1uk in forum Diesel Engine related
    Last Post: 9th January 2009, 06:03
vectra cdti hesitation
vectra c 1.9 map sensor part number
https:www.vectra-c.comforumshowthread.php137702-1-9-CDTI-120-Hesitation-Judder
vauxhall vectra 1.9 cdti juddering
vauxhall vectra 1.9cdti juddering when driving
