Thread: Heated seats (again)
    Jan 2006
    Cardiff
    Default Heated seats (again)
    Had a look around the new car and found all the plugs for heated seats In front either side of the cd player and underneath the accessory socket in the back.Is it a case of just hooking up the seat pads,and away to go,would i need any other wiring or is there any way of telling if the pads are in place already.
    Regular Member rorycarz's Avatar
    Dec 2005
    AYRSHIRE SCOTLAND
    if you buy all the pads & both switches, you will still need to have it tech2 to activate it & it might not work ......best thing to do is buy the switches fit them ( the illumination shoud work )(but the switch wont) & then have it activated at vaux the switch should then work .then you can test the plug under your seat . if ok then get & fit your pads..........pads are a long job & are probably cost £100 so there is not point in doing the hard bit if the rest aint going to work good luck
    then take 1 step futher & do the back to
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Quote Originally Posted by rorycarz
    Total rubbish, see my how to regarding fitting them (In the how to section). I wish people would reply using facts rather than speculate.
    Any problems pm me Steve.
    Paul.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by leeds vectra
    Here is leeds vectra for the front seats, and there is no need for tech2:
    http://forum.vectra-c.com/showthread.php?t=5026
    and here is rorycarz for the back seats, and for the back you do need tech 2:
    http://forum.vectra-c.com/showthread.php?t=8040
    in fact, I'm doubting of doing the last one, but I'm afraid to remove the rear seats and to fit back the leather afterwards... I asked price for it at my dealer; they have never done it before and have to look it up but they think it will be much more than the initially 320 euro as an option on a new car
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Steve,
    The two most important things to bear in mind before buying any parts to do the front seats are:-
    1. Ensure the floor harness for heated front seats is in place. On later cars especially the facelift sri the floor harness is not there, this is because sri's could not be spec'd with heated leather seats from new so they don't fit the loom at the factory. The harness will be there in the dashboard for the switches but stops there and doesn't continue to the floor.
    2. When i did the mod on my 2003 sri, my seats didn't have the wiring harness within them for the heater mats (but the floor harness was there). This bumped the cost up by roughly £100 as both front seats needed harnesses with airbag, pre tensioner, heater pads for back rest and base cushion. The standard seat harness only carries wires for airbag and pre-tensioner.
    Once i fitted everything it worked a treat with no need for tech 2. The earlier the car the more chance you have of completing several good mods by utilising existing wiring:-
    Illuminated sun visors, rear interior light, heated front seats, auto dim mirror.
    Hope this helps, and if you are unsure give me a shout and i'll gladly help you out.
    Paul.
    Dec 2005
    AYRSHIRE SCOTLAND
    sorry to if i miss lead you .i had to have the rear tech 2 to activate my fronts were fractory fitted
    Leicester
    On face lift cars buit after 26th October 2005, there is no loom atall!!!! I found that out nearly too late!!!
    There is no loom from the X plug,m it could be added but what a bog job!! All Vectra dash's are fitted with the same loom no matter what model.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Fair enough mate. I got some bum info over on vvoc a couple of years ago that cost me money. Didn't want a member on here going the same way.
    Paul.
    Jan 2006
    Cardiff
    Cheers guy's for all of you're help, recently changed from a Vectra Sri to a Vectra Gsi so thinking the higher spec car might have a few hidden extras
    no heated seats in mine..
  1. Heated seats again sorry
    By mickeystitch in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2011, 15:43
  2. Vxr seats heated none heated
    By the stig in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2010, 18:33
  3. Heated seats.
    By dave b in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2009, 09:15
  4. Changeing standard seats into heated seats?
    By hanuzar in forum Bodywork & Interior
    Last Post: 6th February 2009, 09:42
  5. Heated seats??
    By ACE.TAG in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2007, 13:27
