Thread: 2.2 DTi exhaust - pipe diameter
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default 2.2 DTi exhaust - pipe diameter
    Hi guys.
    Been doing some reserch on an exhaust and speaking to a local company up here that said they would do me a good deal, but they would need the car for a full day because they don't have the pipe dimensions etc for a 2.2 DTi. They do have moulds for other engines though so do any of the other Vectra exhausts bolt on to a 2.2 DTi? Just means they'll charge me less if they don't have to mock up the entire exhaust system!
    Cheers.
    Feb 2011
    Barnsley, UK
    Trim : VXR
    Engine : 2.8 T V6
    Mileage : 62000
    The 2.2 DTi has a 55mm diameter if I remember right.. I believe this is the same as the 1.9 CDTi, but can't say for definite.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by The_Kink View Post
    Cheers, I thought the 1.9 was the same.
    Anyone else able to clarify?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    the centre section and back box on the 2.0/2.2dti and 120/150 cdti are all the same
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Brilliant. Do the pipes follow the same path? I guess they would have to. If so I can just use the 1.9 moulds.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    I have a 1.9 centre section on my car, direct fit
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    when i cut the cat out i used 2" od pipe up the inside of original pipe which is 21/4" od
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Cheers guys. As long as I know the parts are the same then that's one bit sorted, just the route the pipe takes through the car now concerns me. The boxes might be the same but the route the pipe takes might be different!
    Does anyone have any photos to compare or anything?
    Cheers.
  1. Air box pipe diameter on a 2.0t petrol
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2012, 17:39
  2. 2.0t vacuum pipe inside diameter?
    By tomo41 in forum Petrol Engine related
    Last Post: 15th June 2011, 19:23
  3. 3.2 GSi front pipe diameter
    By Tennants in forum Engine & Drivetrain
    Last Post: 13th June 2010, 22:23
  4. Exhaust diameter
    By Daywalker in forum Engine & Drivetrain
    Last Post: 24th November 2009, 17:51
  5. Flexi pipe diameter
    By damoore1983 in forum General Chat
    Last Post: 22nd March 2009, 21:13
vectra 2.2 dti exhaust diameter
vauxhall vectra 2005 1.9 cdti flexi pipe diameter
does the dti exhaust fit the cdti
flexi exhaust parts vectra c wirral
vectra c 2.2 dti exhaust diameter
vectra dti exhaust diameter
vacuum pipes size vauxhall 2.2 dti
Whats the diameter of vauxhall vectra c 2.2 exhaust system
vectra 3.2 exhaust diameter
vectra c 2.0 dti exhaust test
