Thread: bit of help please
    Mar 2011
    yorkshire
    confused bit of help please
    i have a bit of a problem with my signum, its a 2.0 dti and yesterday had the service light come on and the car die, luckily it happened feet from my house. on opening the engine bay this is what i found, it is the very highest seal on the enginge. there is a bead of oil pretty much all the way round the seal with everything lower in the engine coated in oil. the car has not been overheating and i am unable to say wether it has been down on power since i have only owned the car for 6 weeks so the car has acted as i have always known it. any help with a diagnosis and/or repair information will be more than welcome
    thankyou, aaron
    http://www.facebook.com/home.php#!/photo.php?fbid=2120948742185&set=at.1857904606246. 2111428.1199792489.100000173618483&type=1&theater
    May 2011
    Ilkley
    Sounds like a blown gasket.
    Mar 2011
    yorkshire
    any idea of repair costs?
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    can you upl;oad a pic of the said part?
    cheers
    Mar 2011
    yorkshire
    http://www.facebook.com/#!/photo.php?fbid=224953400853779&set=a.1787388388085 69.50642.100000173618483&type=1&theater
    i have circled the part with red, it is the first joint from the top of the engine casing.
    have been told by a friend it may just be the rocker cover gasket in which case it willmean simply changing and topping oil up. but if anyone may have any different theories i am all ears
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    i cant see the pic.
    Mar 2011
    yorkshire
    hopefully that might work
    Mar 2011
    yorkshire
    http://img171.imageshack.us/i/editvc.jpg/
    the picture is taken from the front of the car,looking to the right hand side of the engine block.the part circled is the gasket with the bead of oil
