Results 1 to 10 of 15
Thread: noisy and leaking injector?
    Feb 2011
    telford
    Default noisy and leaking injector?
    Hi all, my car was ticking over outside earlier and i noticed it sounded a bit tappity. Popped the bonnet and number 3 injector seems to be blowing out oil. Also is very noisy sounds more like a tdci modeo really ticky. Im thinking injector faulty but just wondered if any one else has experienced this?
    Its a z19dth
    Feb 2011
    telford
    If any one could help would be much appreciated or if any one has any injectors for sale
    Engine : 1.9 CDTi
    The noise is probably the gas passing the injector seal.
    There is a guide on here showing how to replace the copper sealing washer.
    Feb 2011
    telford
    Just done number 4 injector mate but did have to disturb number 3 to get it out to be fair. Why would it be blowing oil all around it? Or is it not oil?
    Engine : 1.9 CDTi
    Its diesel sorry not oil.
    As the cylinder is being compressed ready to ignite the fuel/air mixture its finding the least resistance and blowing some out before the rest ignites.
    Its quite common on higher mileage diesel engines and if left the injector is a nightmare to get out.
    Feb 2011
    telford
    That's great mate I' ll pull it out today then. Number 4 was leaking the other week but could see it was diesel.
    Feb 2011
    telford
    What's the best stuff to breakdown the carbon build up around the injector?
    Engine : 1.9 CDTi
    We use Mister Muscle oven cleaner
    Regular Member collyb's Avatar
    Mar 2011
    ireland
    i had this problem on my sri 150 ,,the 3rd injector had aload of oily /tar around its base,,,so i pulled the four injectors and replaced the 4 copper sealing washers on there bases,,,,injector 3 took me 2 hours to get out tho..alot of wiggling and oulling,,just take ur time mate,,and my best tip would be,,if an injector is stuck in hard,,,take a break and a cup of coffee if its getting to u too much..and u cant get it out,,,,trust me ,,it helps to walk away from something for a bit when things arent going ur way,,,also make sure u tighten the securing bracket for each injector down properly,,,, i made the mistake of not tightening them enuf ,,and when i had all back togehter and started the car,,she started chuffing like a steam train,,lol.... just take ur time,,,check and double check everything and u will be grand,,just make sure u change the washers NOW rather than later,,as that tar/oil/diesel substance will keep building up and make ur injector even harder to remove
    Regular Member Si-SRI's Avatar
    Oct 2009
    LINCOLNSHIRE
    Sorry to jump in on the thread...how much did you pay for the 4 copper seals,got 2 on mine weeping slightly so time todo them all.
  1. injector leaking
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2012, 13:10
  2. injector no4 leaking.need advice asap
    By will2.0dti in forum Engine & Drivetrain
    Last Post: 8th July 2012, 13:13
  3. Damn car! (150 cdti injector leaking)
    By John LE in forum Engine & Drivetrain
    Last Post: 29th February 2012, 18:46
  4. petrol injector leaking!!!!
    By mollers34 in forum Engine & Drivetrain
    Last Post: 30th November 2011, 06:10
  5. 2005 Vectra 1900 CDTi 150 Injector Leaking
    By MXB74 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 23:17
chuffing noise from injector vectra 1.9cdti
vectra 1.9 cdti leaky injectors
insignia injector noise
z19dth injector noise
