Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: For those using 'the alternative rear light setup'
    Oct 2007
    Shropshire
    Default For those using 'the alternative rear light setup'
    I work at a trailer place and was looking through the regs for rear lights. I have remembered why the alternative set-up may not be legal.
    To pass type approval the fog light must be 100mm from the brake light.
    Therefore with the alternative setup this regulation is not met.
    However I am not sure if an MOT would pick this up....
    Anyone else agree?
    Oct 2006
    southampton
    15 Post(s)
    nothing has changed with the fog and brake lights setup matey, its only the layout of the sidelights that has been altered......
    Oct 2007
    Shropshire
    No with the original setup the fog light is at the bottom, separated from the brake lights by a distance. With the alternative setup the fog light is next to the brake light which make the brake lights harder to see.
    I doubt you would get pulled but if someone goes into the back of you when the fogs are on (rare i know) because they can't see your brake lights expect trouble!!!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    That info should be put into the how 2, not the comments thread but the actual how 2. Good find Mucklestone
    scottish region
    glad i did not do it lol
    Oct 2007
    Shropshire
    http://www.legislation.gov.uk/uksi/1...hedule/11/made
    Regulation 2 (d)
    Fog light must be 100mm from the stop (fog) lamp.
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Still Gonna Try It..Good Find Though Mate
    Oct 2007
    Shropshire
    Quote Originally Posted by Tam80 View Post
    Well if we are honest how often do we use the rear fogs anyway? lol You could turn turn the top one into a fog and the bottom one into a brake light I believe as the distance would still be retained (basically opposite)
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    81 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    Mines just past the mot with my alternative lights set up.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    Quote Originally Posted by new boy View Post
    mot only inspects the fact it is there in the correct place (on the o/s/r) and works fine and shows red light to the rear of the car and isnt affected by any other bulb operation ....the moveing of it will break type aproval and would void ins if found to be a reason for a crash ...
  1. Alternative interior rear light
    Last Post: 21st February 2011, 10:07
  2. Alternative Rear Interior Lighting
    By dlm71 in forum Styling
    Last Post: 7th March 2010, 19:20
  3. 225/45 Front 215/50 Rear - Setup ok?
    By dennis_signum in forum Handling & Braking
    Last Post: 5th October 2008, 20:41
  4. Alternative Rear Interior Light
    By dwayneoo12 in forum Styling
    Last Post: 8th July 2008, 09:22
vectra c rear light mod
https:www.vectra-c.comforumshowthread.php137680-For-those-using-the-alternative-rear-light-setup
rear light alternative
vectra c alternative rear light setup
vectra rear light mod
