Thread: help from any vehicle painters on the forum
    PRESTON
    Default help from any vehicle painters on the forum
    I recently refurbed one of my alloys and something weird has happened. First i flatted the wheel, then used etch primer on the bare alloy bits, then primed, colour coated and then lacquered, the wheel looked great, all new and shiney. this was about six weeks ago and since then it has been in my garage. yesterday i went to the wheel, it still looked awesome and thought ok tomorrow i will refit it, so applied a coat of mer wax and it looked fine. Today i went to fit it and ,,,,,,,,, the lacquer is full of little cracks???????? Now i used acrylic paint as i was told this is harder wearing but should it have reacted to wax in this way, or have i prepped it incorrectly?
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    58 Post(s)
    Vehicle : Exclusive
    Trim : Vxr half leather
    Engine : 1.9 cdti
    Year : 56
    sounds like wax has reacted with paint. the only thing to do is to flat back and repaint
    PRESTON
    yeah i thought that, but why should acrylic react with a basic wax? this time round i will use good old cellulose,,,,,
    May 2011
    Guildford
    First post...I suspect you used 1k acrylic lacquer from an aerosol, each coat needs to dry off for 5 minutes and only apply thin coats, ie.3-4 to build the thickness not 1 or 2. What has happened is each layer of paint has not fully dried or 'gassed off' and its these solvents that are trapped that has now cracked the brittle film of the lacquer, causing the crazing. I doubt the wax would of blocked up the porosity/film of the paint enough to have prevented the gases (solvent) escaping.
    Your options are to remove the fresh paint with thinners, or wait for a month until everything has fully dried and then flat back, use an isolator coat and then repaint, always iffy when done this way and i would do the former.
    PRESTON
    thanks for the reply burbo, i did use 1k paint and lacquer, thing is this wheel was painted over six weeks ago and left to fully harden. the cracks only appeared after i applied a wax coating and there were none visible before that. looks like its a full repaint, but as i said, this time im going to use celly.
    WGAF#5
    Quote Originally Posted by barney490 View Post
    there is always the possibility that the laquer has cracked owing to the pressure from applying and removing the wax especially if there was only a few coats ...
    May 2011
    Guildford
    Problems dont usually show until around 6 months, quicker in warmer weather..
    Your asking for a reacted mess using celly, best thing it to redo them in waterbase, but that cracked laquer will have to come off or it will show through again.
    PRESTON
    thanks for the replies, started to flat back the wheel tonight, in fact i am goning to flat it back to the primer coat i applied, then paint from there, hopefully i wont get any reactions.
  1. Any good Car painters about
    By Fireyfella in forum General Motoring Chat
    Last Post: 20th December 2011, 16:47
  2. One for you painters and decorators!
    By Vaux-Man-G in forum General Chat
    Last Post: 3rd November 2010, 23:29
  3. painters
    By jb-redbull in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 12:59
  4. Any painters on line?
    By blr123 in forum General Chat
    Last Post: 30th July 2008, 22:56
  5. Question for all painters??
    By ACE.TAG in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2007, 16:56
