Thread: 1.9cdti 150 Servicing Help Please!!
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Default 1.9cdti 150 Servicing Help Please!!
    I want to give my 1.9CDTi 150 a good service, and I mean, a really good service to try and get some more horses back. I have in mind:
    Oil & Filter Change
    Air Filter Change & Hoover Out
    Fuel Filter Change
    Glow Plugs Change
    Could anyone else add to list which would help in gaining more HP?
    I don't want to go down the modifications road, just as far as servicing goes please!
    Thanks!!
    scottish region
    not for hp but change the pollen filter
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    EGR and boost sensor clean wouldn't go amiss.
    Oh and when you do the pollen filter clean all the crap out of the rain channels
    Mar 2011
    Wirral
    Thanks, I've got a list here and adding as I go, bought it with 80,000miles on and don't really know history, oil filter was mingin when I last changed it so doubt much else has been done.
    Pollen filter a good one especially as I get smelly air from vents!
    Anything else that a dealer would do on a full service?
    Sep 2010
    6 Post(s)
    Trim : SRI
    You could look at an activated charcoal filter, that will remove any smells and there are only about £5 more.
    The glow plugs wouldn't be done on a service mate, save the money.
    Check the operation of swirl bar. If it's done 80k then I'd be looking at the cambelt/water pump unless it's already been done.
    Mar 2011
    Wirral
    I will have a look for the charcoal filter, real musty smell it is.
    Would changing the glow plugs help in any way though?
    Wales
    Quote Originally Posted by john506 View Post
    Only if starting is sluggish or problematic. Glowplugs only work when starting the car from cold. Thye will 100%, not do anything for the running or your car once warmed up.
    Feb 2011
    Barnsley, UK
    Trim : VXR
    Engine : 2.8 T V6
    Mileage : 62000
    Only other thing that you could do (that I can think of) is drain and renew the coolant for the radiator and intercooler (and give the intercooler a solvent flush to ensure its clear)
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. GSi servicing.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2010, 21:45
  3. Help in servicing a 1.9cdti/150
    By jacko52 in forum Diesel Engine related
    Last Post: 12th November 2009, 11:12
  4. Servicing
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2007, 21:06
  5. Servicing
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2007, 17:52
