Results 1 to 10 of 23
Thread: Hiss when aircon first switched on??
    Dartford
    Red face Hiss when aircon first switched on??
    Had. Regas 9th April 2011... Started using aircon again recently an was fine not as cold as you would expect but did the job and recently when we switch it on you hear the compressor click in and the engine labour but I'm getting a hiss from behind the vents (so it sounds).
    Now I checked for gas by quickly pressing in the valve on the pipe and it came out quite forcefully and coated my Allen key in green stuff ( is this die?) so I assume the gas is still there.
    I took bumper off and looked at the condenser it has took a beating but can't see no die leaking out... With gas still being in the system Am I looking at a compressor fault?
    My opcom read at idle 750kpa when off and went up to 1200kpa when on but sometimes dropping back as low as 900kpa. I'm told it should be up in the 2000kpa area at idle when on.
    Any input welcome
    Dartford
    It's a 1.9 120 cdti 07 exclusive
    Dartford
    Bump
    Full Member Big Sig's Avatar
    The green stuff could also be lube. The hiss is probably just the liquid refrigerant entering the evaporator and gassing off as normal.
    Dartford
    Thing is it never used to do it and now it's not really cold anymore! I don't wanna just start changing things. Suppose best thing is take it somewhere let them look for a leak.
    Regular Member LADmachining's Avatar
    Hampshire
    The hiss noise when first turned on is indication of the refrigerant level being low in the system.
    It sounds as if a leak detector dye has been added to the system, so that should allow any leaks to be found - of course, the area around the valve you depressed is no covered in dye, so you best tell them you did that or at least give the area a very good clean!
    The condenser is favourite for causing leaks due to them rotting out. It only takes a tiny pin-hole to lose refrigerant.
    Dartford
    Will that stop a condensor leak stop the compressor from pressurising?
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    mine does the same had it to local vx dealer £75 and regas later now waiting for a leak to be found so i can get refund and air con repaired under warranty
    Dartford
    I've writen to kwik fit and complained about the regas I had at Sheffield suggesting they should regas my car im sure they did it wrong it's been pants since they did it. My local kwik fit was spot on.
    We shall wait and see.
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Quote Originally Posted by Rickiw View Post
    Since having my aircon regassed by kwik-fit I have had similar hissing.
    I always had a suspicion that it wasn;t as cold as it used to be either, but havn't used it much.
    Can any one confirm what the kpa should be for the air con as I wouldn't mind checking it myself.
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. Hiss from the front over speed bumps
    By Envy in forum Suspension, Wheels & Brakes
    Last Post: 17th July 2011, 16:49
  3. aircon hiss
    By dubsrus in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2010, 13:17
  4. Air con hiss
    By mcints77 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2010, 21:03
  5. Slightly uneven idle when aircon is switched on?
    By Hideous in forum Engine & Drivetrain
    Last Post: 1st August 2007, 18:08
