Thread: Vectra 1.8 2003 - driveshaft seals leaking
    Regular Member kicker's Avatar
    Oct 2007
    West Midlands
    Default Vectra 1.8 2003 - driveshaft seals leaking
    Hi all,
    After a long journey, i noticed that i've started to get a 'spray' of oil all over the back end of the car. Having got under the engine area, looks like possible drive shaft seels leaking.
    I can't afford to get it repaired till the end of the month but as I've got another long journey to London this week - wanted to top the transmission fluid up just incase. Can anyone tell me/show on pics where I can top the transmission fluid up through some sort of inspection plug/hole.
    There a thread/how 2 on a diesel veccy, but take it in a different location - any pics? Also, anyone have any ideas how much I shoudl expect to pay for replacement of the seals?
    Would appreciate some help. cheers.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Kicker no pics bud but you remove reverse light switch and fill to the lower lip of the level plug.only holds 1.6 litres don't overfill.(switch is near top of gearbox with wiring loom )
    scotland
    there is an oil level plug just behind n/s driveshaft input ( 15mm i think) wen the car is level , fill till oil starts to come out then replace plug .
    the seals are under a tenner to but but driveshaft needs removed to get in to remove old seal and drive in new one .
    HTH
    Oct 2007
    West Midlands
    Cheers guys for the info - very much appreciated.
  1. For Sale: Vectra c prefacelift door seals
    By tommytonguedj in forum Parts for sale
    Last Post: 4th May 2012, 10:09
  2. vectra 2.2 dti injecter seals
    By waynezz in forum Engine & Drivetrain
    Last Post: 27th February 2010, 23:05
  3. Vectra c Chrome Window seals
    By Niks in forum Parts for sale
    Last Post: 3rd September 2009, 18:40
  4. vectra c driveshaft nut
    By stj in forum Engine & Drivetrain
    Last Post: 26th August 2008, 19:07
  5. driveshaft seals
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 25th December 2007, 00:01
changing driveshaft seal on a 2004 vectra dti
opel vectra c leaking oil from drive shaft
opel vectra c driveshaft seal
vectra c leaking from driveshaft
