Thread: brakes binding
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default brakes binding
    ok.. i left work the other night and thought id give the old girl a little bit of stick so i belted the arse off it for a good 9 mile home... erm all on private roads of course!..
    then i came into the village and slowed down but noticed it wasnt driving right but i carried on... then i come to some lights and as i began to stop but the car sort of stopped its self in a way that id not noticed before...
    then i drove off and thought to myself that its taking a bit more effort than usual and i thought i might have a flat so i pulled over...
    it was then ( as it was dark) that i noticed the rear off side brake disk glowing like a 3 bar fire and smelling like holy hell so i checked the other side to find the same thing.... the rear brakes had been binding on but iv no idea why..
    its never happened before in the time iv had the car and its even drove pretty well today while iv been out because iv stopped a few times to check the breaks and im at a loss as to why it did it?
    could it be rubbish brake pads expanding with the heat and binding( as the pads were changed before i bought it), or could the handbrake be just that bit too tight and with me giving it some, its started to bind?
    all thoughts welcome
    al.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    anyone?
    Mileage : 000
    As it was both sides could the hand brake be sticking. It is unusual for both calipers to seize at the same time. Not sure about "cheap" pads, but I would have thought they would not be causing the problem. How does the car drive when it is cold. Do the rear wheels spin freely. Might be a good idea to jack it up and see how the wheels tur, do they sin easily or not.
    Ashington, Northumberland
    More likely if its both at the same time, that the inner cable is seized within the outer. If it was a caliper fault, it would just be the effected side with the portable fire.
    You're gonna have to get the wheels off and have a look at whats going on. Ideally on a ramp. You're gonna need new pads and discs for a start but I suspect you're gonna need a cable too
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    AFAIK, it runs perfect when cold and im able to push the car my self..
    can the brake cable to too tight as it begins to stop the car on the first click?
    al.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    ok... iv just been out having a look at the car again and id say that the handbrake it too tight.
    it stops the car on the first click and almost locks the wheels on the second click( i was on grass)...
    now id say it was too tight and possibly what was causing the binding the other night..
    how do i loosen the cable?
    al.
    Mileage : 000
    How long have you had the new pads. I would say they did not follow the correct procedure in fitting them.?.
    What I would do is remove them. Wind the piston all the way back in then out again, Thus "loosing" the setting it has now. "oh" make sure the handbrake is off, daft suggestion I know but still).
    Then put the pads back in. Obviously do this to both sides.
    Then press the footbrake NOT the handbrake yet!!.
    This will take up all the "play" in the pads.
    If you pull the handbrake first you will use up all the pad "travel" and had no adjustment.
    I am wondering if the handbrake was pulled on first when the new pads were fitted, and then when the footbrake pressed it managed to take the pads in a little more causing the handbrake to "stick" as it was now too tight.?.
    Sodding Typical on Sea
    Very good explanation there, I know it is around in posts and how2's but a reminder is of huge value
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    cheers ed, the pads have been in a couple of months afaik.
    the lad that had the car before me had them done.
    i think il have them to bits this weekend and get them sorted just to be safe
    thanks all
    al.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by Al 22 dti View Post
    thanks all
    al.
    Make sure you disconnect the hand brake cables and check that the levers on the rear calipers are free to move and not seized and the return springs are in place and pulling the levers back to the off posistion.
  1. handbrake binding rear brakes
    By krisby in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2011, 16:36
  2. Ford ranger 2.5 xlt 2004 brakes binding quote
    By sberrow in forum The 'Off Topic' room
    Last Post: 19th November 2010, 12:53
  3. Rear brakes binding! Help
    By tonyblade in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 14:00
  4. N/S Rear Caliper Binding
    By si_hoss in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2010, 10:42
  5. rear brake binding
    By corman in forum Handling & Braking
    Last Post: 7th February 2008, 15:03
