Thread: Please help
    Regular Member mickg's Avatar
    High Wycombe
    Unhappy Please help
    My car just started kangoroing on a low speed. got a power but after 2,800 revs it behaves like i would have a TC on. no smoke from the back and turbo works fine, and on idle is normal. but when i drive it starts cangorooing on 2nd gear and third. Can it be fuel filter and drbirs in fuel? Was ok till todays afternoon. I have re filled on wednesday on morrison station (138.9p per litre).
    The car vectra (55) 1.9cdti 150.
    forgot tu mension spanner light goes on and off avery 2min.
    PLEASE HELP!!!
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Mick how long since you changed fuel filter,never hurts to change if you have done a few miles,the cdti had a problem with softwear and corrosion of injector plug,sometimes has a P0201,P0202,P0203 or P0204 but not allways.
    the wiring harness has been modified from engine no 17000444.
    if reprograming ecu dosn't cure problem Vx advise fitting injector plug's part No 93189918
    first job get codes read before spending is allways a good idea
    High Wycombe
    thankS jonny... went to garage to check it up and mechanic told me it could be a fuel starvation couse of dirt in a fuel filter. will change a fuel filter today. by the way car started agin to drive normaly... weard... some mistoriou thing happene. well no harm fitting a ne filter. cheers for help
    High Wycombe
    Quote Originally Posted by jonnybravo View Post
    the code is P 0203 and it says injector cylinder 3 open or something like that is it expenive? which one is incector 3 on the engine any pics please? opened a bonnet and being hones "blank" dont know...
    cheers
    Jul 2009
    Engine : 20 Dti
    No 3 injector is the third on the right,looking in from front of engine(No 1 is to the drivers side,No 4 to the gearbox side )
    High Wycombe
    thanks guys!!! car fixed it was not injector but injector connector faulty.... like new again
