Thread: 1.8 crankshaft position sensor.
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    Default 1.8 crankshaft position sensor.
    Hi, my spanner light has made an appearance. Along with a few regular codes relating to cooling fan, there is a new one:
    P0335. Crankshaft position sensor circuit A.
    I believe this indicates a fault in the wiring or sensor itself, rather than a fault with crankshaft? Is this correct?
    The sensor is near oil filter i think?. I will check it when I get chance.
    Had MOT recently (not a service) would they be likely to have disturbed it then?
    I also changed oil myself a few months ago, had quite a struggle with filter and whole area got pretty oily, including sensor. I seem to remember two connectors down there. Whats the other one for?
    My cambelt is due in 5000 miles (40000 interval) could this be relevant?
    Since I don't seem to have any mechanical problem, I am inclined to do nothing and see if fault continues to appear. Am I safe doing this?
    Any opinions gratefully recieved.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Yes its under the oil filter, think the other one is the oil level sensor. Quick look on Vaux parts shows they are less than £30 to replace. Might be worth just replacing at that cost.
    http://www.vauxhallworldparts.com/va...number=9115115
    north east
    Best off just replacing, you can take them out and clean them but if it doesnt work it =
    Take out, Clean refit ... take out , fit new one.
    for £30 ish may as well just replace it its probably done 100 000 miles.
    Dec 2010
    Southport
    ok thanks. Now I've seen a picture I think i know the one. I'll check it and clean it, if code recurs new one it is. Cheers for your help. From reading on net it seemed it was more likely to be sensor than actual fault .
    Dec 2010
    Southport
    just out of interest (as rev counter is fine.) does the ECU get its engine speed signal from crankshaft sensor?
    north east
    Not sure but on my mk 4 astra DTI it got the rpm from the gearbox speed sensor.
    Regular Member LADmachining's Avatar
    Hampshire
    Quote Originally Posted by jimmyred View Post
    Yes it does. The crank sensor provides the main timing signal for injection and ignition. If it fails, the camshaft sensor is used as a backup.
    If either cam or crank sensor fail, the engine rev limit is lowered to 4500rpm, rather than the 6500rpm it is normally.
    Quote Originally Posted by roswell View Post
    Don't know where to begin explaining what is wrong with that statement!
    The DTi gets it's engine RPM signal from a crank sensor the same as most other engines.
    Some early Mk4's have a sensor in the gearbox for the speedo. Later models without ABS had a single hub sensor on the N/S/F providing the speed signal - those with ABS the signal comes from the ABS control unit.
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    In the nicest possible way, thank christ for that!! I have a very similar problem. P0011 camshaft position sensor, I replaced both sensors, inlet and exhaust with no cure. Engine runs fine. Keep me informed how you get on.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Quote Originally Posted by disco dan View Post
    Have you checked the security of the wiring, chafes or breaks etc?
    Father in law had this on a PT Cruiser. garage replaced both Crank and Cam sensors to find out chafed wiring to the sensor was causing it!
    Dec 2010
    Southport
    thanks everyone. Not had chance to investigate yet as mrs has just had baby, so been fairly busy!
  1. 1.8 VVT crankshaft position sensor location?
    By disco dan in forum Engine & Drivetrain
    Last Post: 22nd January 2012, 12:35
  2. Crankshaft sensor
    By MORGIE8153 in forum Engine & Drivetrain
    Last Post: 13th December 2011, 17:57
  3. crankshaft sensor
    By valhalla in forum Vectra C / Signum Troubleshooting
    Last Post: 13th May 2011, 13:09
  4. crankshaft sensor
    By morri76 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 20:36
  5. Crankshaft Sensor
    By rhodod in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2008, 23:21
vectra c 1.8 crank sensor location
https:www.vectra-c.comforumshowthread.php137576-1-8-crankshaft-position-sensor
how to check timing and crank sensor on vauxhall insignia 1.8 2011
vauxhall vectra 1.8 camshaft sensor location
vectra c crankshaft sensor
what is diffrent with vauxhall vectra cranck shaft sensors
vectra c crank sensor symptoms
1.8 vectra crank sensor replacement
vauxhall zafira crankshaft sensor location
camshaft sensor vectra c
vauxhall vectra crankshaft sensor problems
vectra c crankshaft sensor location
vauxhall vectra crankshaft sensor location
crankshaft sensor vectra c symptoms
vauxhall vectra c cranshaft sensor fault
vectra 1.8 crank sensor location
vauxhall astra crankshaft sensor location
crankshaft position sensor vauxhall vectra
vauxhall vectra crankshaft sensor location site:www.vectra-c.com
how to replace crankshaft sensor vectra c
vauxhall astra mk5 crank sensor location
how to change crankshaft sensor on a 1.8 astra
replacing insignia camshaft positional sensor
