Results 1 to 10 of 11
Thread: Fitting Parrot MKi9200 tomorrow, need advice!
    Apr 2011
    Workington, Cumbria
    confused Fitting Parrot MKi9200 tomorrow, need advice!
    Hi guys,
    I'm going to fit this kit tomorra, but, I keep seeing that it needs to be connected to permanent live and ignition etc.
    I just assumed it got it's power from the radio cabling from the car. That goes into the iso SOT lead, then into the parrot loom and CD70.
    Which wires do I connect to the cigarette lighter? There are 2 unconnected wires on the SOT lead, one red, one orange. Red says 12 volt ignition/switched, orange says illumination/dash light.
    Please help I'm confused now!!
    South West
    I connected the 12v feed to the black wire on the back of the cigarette lighter. Worked a treat for me. I think it was a blue wire which came out of the SOT 122 harness.
    You will also need to swap the two wires over which have the inline fuses. I think from memory, one is red and one orange. You want it so the top part of red connects to the fuse holder on the orange and vice versa.
    The only other thing is the mute. There are 3 connections.. Again, if i remember correct it was a case of try one and see if it works then the other etc.
    Hope this helps.
    Apr 2011
    Workington, Cumbria
    Cheers for that.
    I've read on here that the yellow mute wire from the parrot loom plugs into the loose pink wire on the SOT lead?
    Also my SOT lead (SOT-122) does not have the blue wire, it has a red wire with 12 volt ignition/switched on it, and a orange wire with illumination/dash light on it pal?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    i fitted mine last week didnt use a sot lead lol my is half can though
    did mine 3 weeks ago
    strangely didnt need to swap over the wires ( red/orange ) it just powered up straight away
    did have one problem
    when i stopped using the parrot for say ipod the radio would come back on with volume that would blow an ear drum !!!
    found out that id put the mute wire into the number 2 mute wire , tried it in number 1 mute wire and viola
    youll understand what i mean by mute wires when you fit it
    word of warning
    before refitting the stereo back into the cage make sure everything works , not like me !!!
    Apr 2011
    Workington, Cumbria
    Guys I need help!!
    I've ran all the cables but I can't get any power to the parrot. Everything is plugged in but not sure about the 12v wire to the ciggy lighter!!
    I need help!!
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Quote Originally Posted by marktaylor View Post
    It will work but does it say 'goodbye' when you switch off the ignition, and does it keep it's memory?
    Apr 2011
    Workington, Cumbria
    For some reason there is no power to the ciggy lighter! Fuse is fine though
    Apr 2011
    Workington, Cumbria
    Actually there is, just rested it. But I still cannot get power to the parrot. All cables are connected that I can see. Stereo loom to sot lead, sot lead to cd70 and parrot loom.
    Swapped the 2 fuse holders over. Just can't seem to get power. There are 2 cables on the sot lead. I'm guessing the red one needs to connect to the ciggy lighter. But tried it and still no power I need help!!!
    Jan 2008
    Lincs
    Year : 57
    Mileage : 100k+
  1. For Sale: Parrot MKi9200 Car Kit
    By AntSSSS in forum General items for sale
    Last Post: 25th January 2013, 21:25
  2. Fitting Parrot MKi9200- Can it run through CD30 aux?(does CD30 even have aux!?)
    By dibble750 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2013, 02:20
  3. Parrot mki9200
    By stanlee in forum Electrical & ICE (including SatNav)
    Last Post: 2nd November 2012, 20:51
  4. Advice needed with Parrot MKI9200
    By trendwarfare in forum Electrical & ICE (including SatNav)
    Last Post: 1st September 2010, 15:33
  5. Parrot MKI9200
    By chris_20 in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2010, 15:10
parrot mki 9200 into vectra c
https:www.vectra-c.comforumshowthread.php137553-Fitting-Parrot-MKi9200-tomorrow-need-advice!
parrot mki9200 vauxhall zafira
vectra c parrot mki9200
parrot mki9200
parrot mki9200 vauxhall insignia installation
mki9200 vectra c no power
vectra c parrot mki9200 sot
parrot mki9200 mute wire
parrot mki9200 installation
vauxhall zafira parrot mki9200
mki9200 cannot mute
parrot mki9200 installation in vivaro what exstra do i need
parrot half can vectra c
parrot mki9200 vectra c iso
parrot mki9200 orange wire
parrot vectra
parrot vectra c
parrot into Vectra
parrot vectra pink
parrot 9200 live wire
