Thread: Car lop sided after changing breakes
    Regular Member 0114NIGEL0114's Avatar
    SHEFFIELD
    Default Car lop sided after changing breakes
    Hi every one ive just done the brakes on my car and disc ive drove around for a few miles but noticed now that the car on the rear on the drivers side sits highter than the passanger side wheel any ideas it does not seem to ne settling down its stayed realy high on the drivers side at the back
    o yes and ive jumped up and down in the boot as well still not gone down all it does is sqweek lol
    Glasgow
    Sounds as if you have a broken spring.
    SHEFFIELD
    More cost again this car is having a joke with me now one thing after another with it
    SHEFFIELD
    Sure its not the shocker
    Sodding Typical on Sea
    I would approach the dealer if the car has a FVSH as it is common knowledge this issue and I have been told Vx will look sympathetically on broken springs, but on a car by car and case by case basis.
    SHEFFIELD
    I thought if the spring was broken it would sit lower not higher
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    did spring come out of its seat when in the air?
    SHEFFIELD
    I dont think so im sure it dint
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like the rear shock has seized, especially as it won't go up and down
    May 2011
    YORKSHIRE
    Mine did same last week after having new rear pads and i do have a knackered absorber !
    went over a speed bump and that levelled it back off but i do need to replace the abosrber check to see if theres oil residue around the absorber and check for scolloping of the tyre around the inner edge which can be another indication that an absorber has failed.
    The bounce check on mine doesn't really give a good result as the springs on the veccy are stiff and my offside absorber is perfect so its compensating the load.
    good luck
  1. Rear Breakes Pads Wearin Before Front ?
    By MCCABE in forum Suspension, Wheels & Brakes
    Last Post: 3rd February 2011, 09:30
  2. Changing from 215/50/17 to 225/45/17?
    By rosssri in forum Handling & Braking
    Last Post: 30th November 2009, 00:18
  3. Changing 215/50 to 225/45 on 17s ??
    By jonesy_ni in forum Handling & Braking
    Last Post: 3rd September 2008, 21:06
  4. Lip spoiler - which double sided tape?
    By Leviathan in forum Styling
    Last Post: 27th June 2008, 08:53
  5. Changing from 17s to 19s
    By welshy in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2007, 22:41
