Results 1 to 10 of 25
Thread: Forthcoming Changes to MOT Test
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Default Forthcoming Changes to MOT Test
    As expected, the latest 'Matters of Testing' VOSA document confirms that next year some of the likely additional inpections in the MOT test will be:
    Continuity of towbar 13 pin electric socket
    Inappropriate towbar repairs or modifications
    Gas leak detection spray to confirm the existence of a leak
    Rear passenger doors opening
    All door hinges, catches and pillars
    Catalytic converter missing
    Inappropriate brake system repairs or modifications
    Defective ABS or ESC components
    Front and rear lights single operation
    Main beam warning light
    Steering lock mechanism
    Illumination of malfunction indicator light (MIL) for electronic power steering, electronic stability control, electronic park brake control, brake fluid warning lamp, tyre pressure monitoring system and air bag/ pre-tensioner
    Driver’s seat adjustment
    Speedometer
    Headlamp cleaning and self-levelling if high-intensity discharge (HID) lamps are fitted
    Products on the lens that reduce light output
    Battery and wiring
    Power steering oil level
    Damaged or corroded power steering pipes or hose
    Engine mountings
    Steering joint dust covers
    Inappropriate steering repairs or modifications
    Steering lock stops
    Steering box oil leakage
    Inappropriate suspension repairs or modifications
    Drive shaft support bearings and coupling gaiters
    2.5mb file MOT Matters May 2011
    Woodbridge
    so aftermarket HiDs will fail?
    Full Member Big Sig's Avatar
    So would a missing main cat fail if you still had the precats?
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    bad news for many, it's been on the cards since the last issue though.
    interesting that there's no mention of banning chips/remaps yet, mind.
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Ouch thats gonna hurt many on hear with HID's. Lots of swapping to VX parts just before MOT time then swapping them back again. Mind you now the police will have a field day. I foresee a crack down coming.
    I was starting to think of going down the HID route but that puts pay to that.
    EDIT : Could be a silly question but would my newly accuired eyebrows possible fail a MOT? or am i just being silly
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    So what will they do, poke a stick up ya zorst to see if the cat is still there? Meeeeowwww.
    Mine is there but empty??
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    lol I was thinking more about HIDS
    Regular Member VectraElite 2.2DTi's Avatar
    Sep 2010
    Longfield
    ive got HID's and a de-cat the de-cat is with a straight through pipe
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Mine should still be ok, wife has tyre pressure mpnotoring on hers, one more thing to go wrong.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    power steering fluid level
    How are they gonna check that on the Vec's/signums with the remote tank?
  1. Testy test test.......
    By Mikey4996 in forum Signature & Avatar Testing
    Last Post: 25th September 2011, 13:01
  2. testing test test
    By muad_dib77 in forum Signature & Avatar Testing
    Last Post: 19th February 2011, 20:15
  3. Test
    By Stevel in forum Signature & Avatar Testing
    Last Post: 23rd June 2008, 23:34
  4. t t t t test
    By Big Sig in forum Signature & Avatar Testing
    Last Post: 20th June 2008, 05:26
