Results 1 to 1 of 1
Thread: Brake Fluid Leaking On to Foot Pedal
    Nov 2007
    Stourbridge
    Default Brake Fluid Leaking On to Foot Pedal
    Hi There Just Wanted some advice and information on my problem.
    I only Noticed the problem on a tuesday afternoon when the clutch pedal went squeaky all of a sudden so i jumped on here and realised its the spring...few hours later ordered it and picked it up the same day.
    i couldnt be bothered changing it as i had it booked in for a quick brake pad change so i let him get underneath the footwell and sort it but after investigating it the mechanic said i got a brake fluid leak comming underneath there which has been dripping on the spring and plastics which has caused your spring to mess up he said its pointless changing it untill youve sorted the leak out. i know where the leak is on the inside and out side just wanted more information on the part number or what you call the darn thing clutch pedal cyclinder?? pic attached thats from opening the bonnet you can see the leak.
    any help appreciated (1.9cdti 120bhp 57 reg) taa lads!
    If you follow the threaded hose from the resevoir bottle and it feeds inside to the fotwell area
  1. brake fluid leaking signum 3.2v6
    By david106 in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2012, 21:25
  2. brake pedal/fluid
    By b1lly in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2012, 23:34
  3. Washer fluid leaking
    By monty2000 in forum Bodywork & Interior
    Last Post: 3rd February 2012, 11:47
  4. gearbox fluid leaking ?
    By pro auto valet in forum Engine & Drivetrain
    Last Post: 25th October 2010, 19:59
  5. Is this a leaking brake fluid bleed nipple ?? (pics)
    By simac in forum Suspension, Wheels & Brakes
    Last Post: 16th December 2007, 20:10
brake fluid on clutch pedal vectra c
