Thread: Retro fit Face-Lift Headlight Washers
    Feb 2011
    Question Retro fit Face-Lift Headlight Washers
    I am looking at fitting the face-lift headlight washers I can see that ther are several bits that I need but have a few questions.
    Does anyone know how the washers are actually fixed to the bumper and is there any markings for them on bumpers that don't already have the cut outs.
    Is there any wiring/relays that need to be fitted? i know I need to change the washer bottle as it's bigger but no sure about the pump.
    Any help is much appreciated.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    the washer fix via a clip that goes on the underside of the bumper/jets. The bumper is marked out already. Wiring may/may not need to be fitted depending on your car and an extra pump will be required.
    Do a search for "headlight washers" and you'll find more info.
    Feb 2011
    Cheers Lofty, had a good look through the how 2 which I think answers all my questions. Hadn't looked before as I thought it was just for pre face-lift.
    Feb 2011
    One last question, couldn't work out if they need to be Tech2'd once all fitted or do they 'just work'?
    @home
    Engine : 1.9 CDTi
    Quote Originally Posted by Meady View Post
    you guessed it..... tech2 required
    Feb 2011
    Quote Originally Posted by lofty View Post
    Cheers Lofty
  1. retro fitting headlight washers
    By taffy bhoy in forum Styling
    Last Post: 21st September 2011, 14:10
  2. face lift headlight conversion....
    By Mopar Man in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2011, 22:23
