Results 1 to 7 of 7
Thread: Fan motor squeaking
    May 2011
    Leeds
    Default Fan motor squeaking
    I have just bought a 53 2.0T Vectra and found that the fan motor squeaks, i guess it's to do with water contamination because i have had to change the resistor so the fan would blow on all speeds. i was planning on spraying WD40 in to the fan through the pollen filter opening; has anyone any thoughts on this or had the same problem and fixed it.
    Thanks in advance
    Ely, Cambridgeshire
    63 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    That's exactly what you need to do, but DON'T use WD40, it dries out and leaves a sticky residue as it does which will make it worse over time. WD40 is a penetrating and freeing up fluid, not a lubricant. Get yourself a can of spray 3 in 1 oil and use that instead.
    Regular Member Al 22 dti's Avatar
    Mar 2011
    pontefract
    Vehicle : 57 zafira 1.9 cdti design
    Trim : design
    Engine : 1.9 cdti
    Year : 2008
    you CAN use wd40 as a quick fix but as above, it does dry out.
    you'l find that the bottom of the fan housing is probably got or had water in ( very bad design) and what i did was drill a 10mm hole in the bottom to drain any water out and provide access to the bottom fan bearing for oiling.
    hth
    al.
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    I used WD40 on my old 2.0T and it worked a treat right up to when I traded it in 18 months later, and presumably afterwards.
    My problem was caused almost certainly by previous water ingress through the pollen filter caused by a blocked drain.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Year : 2008
    Quote Originally Posted by john_k_sri View Post
    this is true but when the water drips down past the motor, it sits in the bottom of the housing and rots the bearing.
    its a realy bad design fault made by vx
    al.
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    Quote Originally Posted by Al 22 dti View Post
    al.
    Guess I was lucky, as I was told that the water had rotted away one of the grommets into the (bulkhead?).
    And quite unsurprisingly, it was not identified during the Network-Q 114-point pre-sale check. TBF the dealer did sort it PDQ when I told them the passenger footwell was wet.
    May 2011
    Leeds
    Thanks for help guys, all sorted now.
  1. Squeaking heater fan
    By waterbourne in forum Bodywork & Interior
    Last Post: 30th January 2012, 19:44
  2. squeaking from ns rear
    By paulf in forum Suspension, Wheels & Brakes
    Last Post: 10th February 2010, 21:53
  3. Squeaking Noises
    By MrLOL in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2009, 20:33
  4. squeaking from brakes
    By baz2003uk in forum Suspension, Wheels & Brakes
    Last Post: 12th August 2007, 23:28
  5. Another Squeaking Noise
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2007, 07:54
