Results 1 to 10 of 29
Thread: How to lower exhaust gas temperatures?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default How to lower exhaust gas temperatures?
    My question is...how to lower exhaust gas temperatures in the combustion chamber, without excessive tuning of the engine's injection system (I'm having in mind the water-methanol thing) ? My engine is the 3.0CDTi and it would really benefit from it (as it's this what kills it), as would probably any other engine.
    Feel free to start a debate, as I'm really interested in your opinions (especially from the owner of the heavily tuned 1.9 ).
    West
    Nutron & Harvey are both running water/meth set ups
    EVERYWHERE
    The V6 has a very short stroke for a diesel engine. It's actually about the same as a 3 litre 6 cylinder petrol engine. This doesn't help the cylinders ability to dissipate heat very well after the compression stroke. It's one of the reasons that the V6 never received much in the way of bhp upgrades in the same way that the longer stroke engines of BMW, Merc and Audi etc have.
    Bore 87.50 mm × Stroke 82.00 mm 3.44 in × 3.23 in. Isuzu 3 litre
    Bore 84.00 mm × Stroke 90.00 mm 3.31 in × 3.54 in. BMW 3 litre (current spec)
    Bore 83.0 mm x Stroke 91.4 mm 3.27 in × 3.60 in. Audi 3 litre (current spec)
    Bore 83 mm x Stroke 92 mm 3.3 in x 3.60 in. Merc 3 litre (current spec)
    It's limitation is that it was purposely designed for FWD cars that needed a compact but refined engine. It's also not helped by having gearing that's too low on the manual cars.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Can certainly see your point there mate. The stroke is 10mm! shorter compared to the 3.0 merc diesel
    How about a remap that's specified for better economy, not higher power output? Would that somehow lower EGT's? I'm looking into SKN Germany offers for ECO-Tuning, but their remaps cost 1000€!!
    http://www.skn-tuning.de
    ECO-Tuning map
    Standard: 130kW/177PS, 370Nm
    Remap: 140kW/190PS, 400Nm
    ECO-Tuning map + higher output map on full throttle
    Remap: 155kW/211PS, 440Nm
    EVERYWHERE
    Quote Originally Posted by Celes View Post
    It doesn't help with the development of more power, unless you're prepared to burn considerably more fuel in order to achieve it. Which brings us on to your next question....
    ECO-Tuning map
    Do you actually use the full amount of power and torque that you already have available in your engine? Why do you think that increasing these will lower EGT's?
    Frankly the mind boggles at the suggestion that actually increasing the engines output at any part of the rev range will lower EGT's or indeed improve fuel economy in a car that already has more than enough grunt in the first place.
    I'm sure that these so called 'eco maps' are just way of getting people to buy remaps for another reason. A true eco map that saves you fuel and lowers EGT's would probably involve detuning your engine and fitting a very heavy accelerator pedal spring. But who's going to buy that?
    If you want to lower EGT's, the simple way is to use less fuel. You may actually want to think about removing some power and torque from the engine. Have a sort of lazy variation of a 1.9 150.
    If they had done that on the Saabs, they probably wouldn't have had any problems. LOL
    Sodding Typical on Sea
    Sadly the best way to cool the exhaust stream is to use a recirculated exhaust gas, as it fills the space void that react-able fresh air would otherwise fill.
    EVERYWHERE
    Quote Originally Posted by Derek Mc View Post
    This is true. But sadly, also very misunderstood.
    You obviously can't use it at full load or full throttle where EGT's would be highest, but it does help to cool the engine more during the time that it isn't under full load or full throttle, which is about 95% of the time.
    Think of how you would increase EGT's, and then do the opposite.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Thing is that when I drive in Germany I always have that underlying fear, that the cylinder liners will let go under full throttle. Not that I use all the power all the time, but still, driving at 120-130 for extended periods of time is not good for this engine, even though some say that if you're under 4000rpm you're safe...
    EVERYWHERE
    It's time you got yourself that F40 box with the 3.35 or 3.09 diff.
    Seriously though. Increasing the fuelling at those revs or any other revs will only increase EGT's (if you use all of the extra power). Only other thing to suggest is that you don't drive at 120-130 for extended periods of time. LOL
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Read this before listening to Diesel Dog:
    http://www.vectra-c.com/forum/showthread.php?t=137471
    Increasing fuelling at higher revs would reduce the power and produce more black smoke, at high revs there is more fuel than air and adding more would make that worse.
    Think of the reason that the EGR is closed under hard acceleration, it would restrict the amount of air going into the cylinder by mixing the 'clean' air with 'dirty' air from the exhaust and produce less power but increase black smoke due to more unburnt fuel due to the lack of oxygen.
    Possibly water/methanol:
    http://www.methanol-injection.co.uk/
  1. Lower EGR Exhaust pipe.
    By Dunny in forum Engine & Drivetrain
    Last Post: 16th September 2011, 17:19
  2. Rear lower spoiler and the twin exhaust....?
    By Marty 1888 in forum Bodywork & Interior
    Last Post: 16th March 2009, 21:56
  3. lower exhaust trim?
    By big rich in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 28th December 2008, 16:02
  4. SRI SPRINGS, SRI EXHAUST and LOWER SPOILER
    By Silver V in forum General Chat
    Last Post: 10th April 2007, 17:50
vauxhall v6 injector spray pattern
