Thread: Connections on Travel assistant (Power/earth etc)
    Engine : 1.9 CDTi
    Default Connections on Travel assistant (Power/earth etc)
    Can anyone tell me the what the connections on Travel assistant connecter are please (Power/earth etc).
    I took the socket from another car but all the connections f the plug were full. and the guide only shows power and earth connected so I need to know what they are so I can wire it in.
    Engine : 1.9 CDTi
    B t t t
    the power and earth leads for the floor mounted plug come on a harness that plugs int the floor plate and then you run it to the rear fuse board
    just a quicky as well , when you got the floor plug from the other vehicle did you also get the four pins that screw into the sides of the middle seat ??
    Engine : 1.9 CDTi
    The plug on the floor has ALL the pins connected and fully wired with ALL pins used.
    That loom then went into the main loom that goes forward to under the dash. Thats why I need to know what wires I need to use ie what pin is live and what one is earth.
    I think it is like this as it was speced when it was bought.
    And yes I have the bits for the middle seat (We swapped middle seats as the trim was the same)
  1. Heated seat live/earth connections
    By signum_rob in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2011, 12:58
  2. Travel assistant
    By Elevonic in forum Bodywork & Interior
    Last Post: 1st October 2007, 20:16
  3. Travel assistant
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2006, 19:08
