Thread: Water, condensation or misted Fog Lights (Foglight)
    Luton
    Default Water, condensation or misted Fog Lights (Foglight)
    My theory is that the foglights have a vent on the back, which lets in water, particularly the N/S/F foglight on my facelift Signum 2.2. The vent is about the size of a 10 pence coin, and is on the back face of the housing.
    What I have done is sealed up the vent - I squirted some sealant (silicone rubber) into the groove around the edge of the vent. I then got some windscreen washer tubing, and drilled a hole through the inside face of the foglight housing to accept the tubing - watch where you drill. Run the tubing high up into the engine bay, tie wrap in place. Align the open end of the tube so that it is facing the windscreen. Seal around where the tube enters the foglight housing.
    Be aware that the housing is made of polypropylene, which is difficult to glue or seal. Loctite do a special primer - I think it is Loctite 770 - for Polypropylene if you want to glue a boss onto the housing for the tube. Otherwise don't disturb any sealant bead once it has set.
    I did this mod last Autumn and have not had a problem since ...
    (Keywords - misting, foglight, foglamp, condensation, water in Foglight)
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    I was told by someone on here that the NSF misted foglight is a sign you have been over filling the water bottle. And it leeks round the seal onto the light.
    Why didn't you just fit the proper snorkel kit, or put some dessicant (moisture absorber / silica gel) in the base of the inspection cap?
    Nov 2010
    BRECHIN
    Would get away with dry rice stuffed in a empty teabag aswell worked for me
    Luton
    The seal on the washer bottle is fine - and not over filled.
    The O/S/F vent is better protected from the elements as the Power Steering unit acts as a shield for the vent.
    Silica gel needs regenerating after it becomes fully saturated.
    Each to their own solution.
    PS - at one time there was 1 cm of water in the base of my Foglight. A relative has a 2006 Saab - that too accumulated water in the foglight during very heavy rain.
    Full Member Big Sig's Avatar
    I just used to leave the cover off altogether!
    Quote Originally Posted by omega2498 View Post
    Change mine once a year. Takes me less than 2 mins to change. Don't even break out in a sweat doing it.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Me too, but I replaced it when the foglamp cleared. Then I drilled a hole in it and plugged the hole with a plastic bung, so I could just remove the bung to aerate the enclosure without removing the cover.
  1. condensation in lights
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2013, 21:39
  2. Condensation and Water....
    By GazVXLINE170 in forum Bodywork & Interior
    Last Post: 1st December 2010, 09:18
  3. misted head lights
    By woodze in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 19:05
  4. Boot well water/ Condensation
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 22:27
  5. Misted Lights
    Last Post: 30th November 2009, 22:20
