Results 1 to 10 of 11
Thread: failed CD70 update, oops
    NULL
    Default failed CD70 update, oops
    Oops, what have i done!!!!!!!!
    I didnt read anything untill it was too late,
    Failed update, just sat there for 2.5 hours without a progress bar, so i reset it.
    Took disc out, but lost radio and navi obviously. tried to access hidden menu but only the BC button works now, press audio or what ever it is doesnt bring the other menu any more.
    I have found the original 2005 language disc i have put that in now it gets as far as 0% and then just loops.
    I couldn't eject disc so i carefully stripped the drive down and removed the disc manually.
    Will a new up to date genuine disc sort this issue or is it now dead??
    Thanks all.
    As tempting as it is i would rather you didnt start firing all sorts of abuse at me!!! i already feel like a right t!t.
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Hi !
    If you cannot repair I can help you, two variants: or you sell it as spare parts (i buy from you) and buy another OR send to me for repair. First part is a little expansive than second part.
    CristianTM.
    Aug 2010
    Stoke on Trent
    Quote Originally Posted by jamesworts View Post
    Yes it WILL (almost certainly) sort it out... I have had to do this after 'bricking' mine and so have one or two others here... the fix is to order the disk from the stealers... put the disk in and leave it (go for a cuppa)... do not try and start the car (or indeed turn it off) during the update. It will take a little while (15mins or so) but it should eventually restart and be fine from then on...
    NULL
    It has been suggested that i remove fuse 26 and fuse 1 1=radio 26=display, I did leave radio disconnected for about 7 or 8 hours and still no good.
    I tried to update with a 10.10.2007 disc, the original one that i have is a 2005 one but it is looping at 0% because i tried to update with 10.10.2007 will it have to be a newer genuine disc than 2005? or is it stuffed if it wont accept my original 2005 disc?
    Quite worried about this. onlt had the car since monday and already i've trashed it!!
    Aug 2010
    Stoke on Trent
    The only way to know is to get hold of a 10.10.2007 disk... they're only a few quid from the stealers.
    NULL
    ordered one this morning, should be available tomorrow morning. i hope.
    Regular Member PORKBALLS29's Avatar
    Epping
    Just out of interest how much is the disc costing?
    NULL
    about £7.00 i believe, although i did ask them to VOR it for tomorrow so may be a bit more. but dont care if it fixes it!! lol.
    Regular Member KeeronMac's Avatar
    Mar 2011
    Donegal
    Same thing happened to me, genuine disc sorted it out
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    Anyone got a current part number? mine needs updating
  1. tried but failed! An update....
    By craig-s in forum Engine & Drivetrain
    Last Post: 14th February 2012, 15:05
  2. Big oops or small oops? infor needed
    By davidmcd2002 in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2011, 17:44
  3. Failed CD70 firmware upgrade
    By FatPete in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2010, 19:10
  4. CD70 update cd
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 10:59
  5. cd70 update?
    By JonR in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2007, 21:30
