Results 1 to 2 of 2
Thread: Help!!
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Default Help!!
    My engine block symbol on the dash of my 2.2 direct came on for approx 10 miles on the way home from work yesterday and I had intended for the car to go to the local stealers to have it checked out. However when I drove it to work this morning the light did not come on. Has this happened to any one before and should I still contact the stealers etc etc. Don't know what to make of it as the car drove as per normal.
    if it re-appears again, then yes..
    a code will have been stored and they should be able to tell you what it is straight away..
    as the car still runs fine then i wouldn't rush out to do it, not unless it occurs again.
