Results 1 to 10 of 17
Thread: alternator belt setup need asap help
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default alternator belt setup need asap help
    Need help asap. I've just changed my tensioner pully on the car but I can't seem to figure out how the belt goes also do you have to retension it or is self tensioning. Could someone do a diagram of the setup of the belt cars a 2.0dti
    Oct 2009
    Sandwell
    Belts sorted but I can't seem to get it over one of the pullys what I mean is I come to the end part to be put on but seems like the belts to small but its the correct part.
    you will need to get a socket or spanner on the raised cast hex that is on the tensioner in order to retract the tensioner pulley far enough to allow you to slip the belt over the final pulley. These things can be really tight and you may need to use a breaker bar or similar extension in order to get it to move.
    Oct 2009
    Sandwell
    spent 10 hours on it today and sitll aint done it, i got the belt on but done it like this
    undone the bottom tensioner bolt then the belt went on its on all pullys but the bottom bolt wont aline up with the bracket due to the tentioner piston needs pushing pu (easy said than done) so what im going to do is get 2 trolly backs and a bar and push it up that way , do you think thats alright? if not whats the best way to tension the tensioner?
    Engine : 1.9 CDTi
    What engine code is it as my Autodata might show it
    Oct 2009
    Sandwell
    Quote Originally Posted by lee gsi View Post
    aint sure mate , all i know its a 2.0dti will it say on logbook?
    I can see what you are proposing and it may or may not work but if you have fitted a brand new tensioner have a read of what I have put below
    before you try it
    From the Haynes book. If a new unit is being fitted or if the damper strut was not stored in an upright position when removed, it must be bled by mounting it in a vice and operating it over five or more full strokes. Each stroke must be at constant load and speed to avoid damage to the unit. Place the tensioner assembly in position on the engine and refit the pivot bolt and damper strut lower mounting bolt. Tighten the bolts to the specified torque and refit the belt.
    Oct 2009
    Sandwell
    Quote Originally Posted by Rapala View Post
    before you try it
    yea mate ive done that, might be engine y20dth
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    if you need the diagram i can get you one to night and email it you, just ring me 07990558626 if you need it still the easiest way is to just push the tensioner back when trying to put the belt over the last pulley, some times easier with 2 peopel one for puting belt on while other holds a breaker bar on the tensioner while slackening it of enough to get belt over last pulley wheel
    Engine : 1.9 CDTi
    I dont have the info sorry
  1. New alternator and belt
    By Mark-R in forum Engine & Drivetrain
    Last Post: 14th September 2012, 17:20
  2. Alternator Belt! HELP A.S.A.P
    By rwellfair in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 07:43
  3. Alternator... need help ASAP please!
    By Berto in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2009, 23:52
  4. Signum 2.0t alternator belt
    By turbohaggis in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 11:37
  5. dti alternator belt help
    By rorycarz in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2008, 23:09
signum alternator setuo
