Results 1 to 10 of 16
Thread: Cost of replacing a consumer unit
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    Default Cost of replacing a consumer unit
    Hi guys, ive just been quoted over £700 to have the wiring tested and have the consumer unit replaced into a 2 bedroomed house bulit in 1980. - I think this is really heavy, what do you think?
    Any ideas on what price i should be looking at?
    Any electricians in the Harrogate/Leeds/York area want to give me a quote send me a PM
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    A new CCU with breakers will cost you around £100 - £150 from a wholesalers, do you know how many circuits you have, id imagine a 2 bed house has between 4 and 7 circuits, thats about two to three hours work, and a test for part p, don't forget that a new CCU has to be notified under partp of the building regs aswell, so you'll also have fees from your local building control.. £700 is too high though..
    I dont know anyone in your area but TrustaTrader may help
    http://www.trustatrader.com/
    Dunstable
    Exactly as pete said. I'm sure you'll get it cheaper than that. Split load boards can be anything from £70.00 upwards, including breakers. Notification to building control can be done through whoever the electrician is registered with, so he should give you a price for fitting, notification and testing. Rough guess £300-£400. Might get the cost down if you buy the consumer unit yourself, you'll have to know what to get though and what size breakers you'll need for your circuits.
    Regular Member !tf's Avatar
    Apr 2011
    Chesterfield/Sheffield
    If you looking at buying the consumer unit yourself and need some guidence drop me a PM mate. Im an electrical apprentice qualified at level two just about to move onto level three.
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Quote Originally Posted by !tf View Post
    Guidance is good, but no subsitute for a proper install especially as a CCU change will more than likely mean you have to remove the main fuses or do it live, which I dont recommend a novice do, A new CCU is notifiable under PartP, so it'll need to be notified to local building control, upto you if you don't tell the LBC, but as yours is a 1980's era build it'll be obvious if you sell it that there's been a CCU change at some point and you may be asked to provide paperwork before a sale goes through..
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    Quote Originally Posted by Big-Pete View Post
    I'm not even going to consider doing this myself, but thanks for the offer of guidance anyway - with me being colour blind i dont think it would be a good idea!
    Also, i would like to have it properly certificated should i sell the property - so its gonna have to be a professional install.
    Thanks so far guys
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Parts are 100 quid ish time 200 quid testing 100 quid, 500 quid max imo
    Jan 2010
    Middlesbrough
    Yes, parts may be inexpensive nut i wouldnt recommend that you buy them and ask the electrician to fit them.
    As an electrician I would not fit a cheap consumer unit, some of the cheaper makes are an absolute nightmare to work with - very little space inside to terminate the wiring, poor quiality etc
    I agree that the price you have been quoted is on the expensive side but to carry out a full periodic inspection and replace the consumer unit should be a full days work.
    I suggest you get another couple of quotes, ensuring that all are from a part p registered spark. Dont forget that whoever does it must give you a Electrical Installation Certificate, followed by a notification from building control
    Regular Member hutch's Avatar
    Sep 2010
    TELFORD
    B and q have a 10way fully populated unit for 50 quid. Superb.
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    I had mine replaced last year with the new style RDC board.. 10 brakers , 2 RDC's and 2 main trips, fitted , tested and signed off to the local council, £290.
  1. moving a consumer unit??
    By paul.sessions in forum The 'Off Topic' room
    Last Post: 30th December 2012, 09:10
  2. Cost of replacing
    By johnny kebab in forum Engine & Drivetrain
    Last Post: 2nd December 2012, 16:18
  3. cost of replacing injector seals ?
    By Rocky Balboa in forum Engine & Drivetrain
    Last Post: 20th January 2012, 21:36
  4. cost of replacing tyres
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2010, 07:48
  5. Cost of replacing entire auto dimming door mirror?
    By Elite Estate in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2008, 21:04
cost replace consumer unit
