Results 1 to 10 of 15
Thread: Dashboard illumination gone mad
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Default Dashboard illumination gone mad
    Yesterday when coming home from work i noticed that my fuel gauge was only half lit, i thought that one of my white leds had failed, but when i got home and turned the lights off the broken half of the fuel gauge lit up and the heater controls remained lit even after the car was locked. I disconnected the battery for 30mins to see if that fixed it but had no effect. Has any one got any ideas what happened?
    Regular Member Reevo's Avatar
    Nov 2010
    Leicestershire
    Try disconnecting the plug under the plastic steering column shroud?
    Aug 2009
    Trim : SRI
    Mileage : 50000
    I cleaned the ABS plug and the CIM module under steering wheel shroud and no effect,
    I was sitting in the car tonight with then turned lights off and the fuel gauge and the heater panel were still lit for exactly 30 seconds the went off (The heater panel is dim and half of the fuel gauge is bright), when the side light are on all lights are bright except the half of the fuel gauge that is off.
    Would this be caused by a faulty CIM module or something worse?
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Are you sure there's not a short on the dash? Shorts can do strange things.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Aug 2009
    Trim : SRI
    Mileage : 50000
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Its just strange that it is is just one led in the speedo cluster (right side of the fuel gauge) and the heater panel, I am wondering if one of my white leds in cluster is faulty.
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by ScotsDragon View Post
    If there is a short it could be causing the oddest of faults - as all a short is, is just electrical current taking a path it shouldn't. Then if you look at the intrument binicle circuitry it ain't the simplest, personally I would check to see if there is anything obvious.
    All a faulty LED will do is either go on or stay off, when it does it is down to circuit conditions - if the circuit is complete or not.
    Gazza4
    milton keynes
    Who did your conversion , and what type of soldering iron did they use?
    Aug 2009
    Trim : SRI
    Mileage : 50000
    Quote Originally Posted by kman247 View Post
    I did it myself using a weller variable temp iron, But that was months ago.
    Aug 2009
    Trim : SRI
    Mileage : 50000
    Going to remove speedo and check leds and circuits and see if there is anything wrong,
    How else can i find the problem?
    milton keynes
    OK , as long as you adjusted the temperature accordingly whilst carrying out the conversion and didnt overheat the circuit boards it shouldnt be that. I have mentioned many times not to use the wrong tools for the job , as problems may arise months later and not necessarily at the time of the conversion.
    If it was me I would unplug each unit and see if the same problem occurs , if it does its more likely you have an issue with an ecu such as the CIM.
  1. Hi-Fi Illumination Fault HELP!!!
    By Gogs67 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2012, 14:33
  2. CD70 illumination
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 19th August 2009, 15:26
  3. Footwell LED Illumination Query
    By Jezzy in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2009, 22:00
  4. Instrument illumination
    By steve1975l in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2008, 01:56
  5. CD70 illumination
    By Big Dave in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2008, 10:36
