Results 1 to 3 of 3
Thread: Chugging & blue smoke
    Aug 2009
    Ascot
    Default Chugging & blue smoke
    Hi,
    When I leave my car for long periods (8+ hours) when I start it, it chugs for about 30 secs and kicks out loads of blue smoke. After about 30 secs the engine levels out and the smoke goes?!?!
    I have changed fuel filter and the car actually has no problems starting and does not nearly stall it just sounds rough.
    Could the inlet manifold be causing this?
    It also runs fine when warm
    Nick
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    My cdti does the same, I was told it was because of the high miles (130.000) as the seals on the pistons are wereing out and when it sit's still the oil will drip past the seals and when you start up the oil has to burn of so comes out the back in blue smoke.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    130k is no high miles. Certainly not for piston ring failure on the 1.9, which is a VERY robust engine.
  1. blue smoke
    By Swedge in forum Engine & Drivetrain
    Last Post: 28th October 2012, 13:09
  2. Blue Smoke
    By Monkgti in forum Engine & Drivetrain
    Last Post: 30th July 2012, 16:31
  3. Blue smoke/Chugging!.
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 18:21
  4. blue smoke
    By matt.d in forum Engine & Drivetrain
    Last Post: 26th June 2011, 11:34
  5. 2.2 blue smoke
    By pyper_honda in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 22:52
vectra c chugging
