Thread: FOG LIGHT - FUSE HELP REQ- Urgent
    HULL
    Default FOG LIGHT - FUSE HELP REQ- Urgent
    Hi
    I hit something on the road today and it has dislodged my Front Fog Light , The warning light is on and front fog message , But NONE of them are Working - NOT even the REAR ones , Could this be the Fuse ?? , if so can anyone tell me which fuse it would be
    As i have 1st MOT tommorow...Typical
    VECTRA C - 2008 SRI CDTI
    Many thanks
    11 Post(s)
    If you've not got a handbook to refer to for the fuses, you can download one from Vauxhall's website.
    As there is only one rear foglight (unless you've moddied it for two?) - are you sure the rear bulb hasn't blown?
    Dunstable
    Is it just the foglights that aren't working, do your headlights / sidelights all work. Don't think there is a seperate fuse for the foglights. Don't forget your headlights need to be on first before you can turn on the fogs.
    HULL
    Cheers Guys ..
    Sorted , I only had my Side lights on ..LOL.. Not my mains , all ok just need to fix fog back into its slot now.
    Cheers again
    11 Post(s)
    The rear fog light will work on side lights IF you've got your front ones on as well, otherwise as you've just found out - you need the headlights on.
  1. instrument light fuse ?
    By neilb1 in forum The 'Off Topic' room
    Last Post: 20th March 2012, 10:26
  2. front fog light fuse
    By nigelbriggs in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2011, 09:51
  3. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  4. Interior light fuse?
    By Knight Rider in forum Electrical & ICE (including SatNav)
    Last Post: 2nd May 2008, 19:03
  5. Urgent or not so urgent ?? Service Warning Light
    By martinh67 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 09:54
vectra c foglight fuse location site:www.vectra-c.com
vauxhall vectra fog light fuse
vectra c fog lamp fuse
fuse location of fog lights on a vectra 05
fuses for the lights and fog lights on a 2006 vectra
where is the fuse for front fog light on a vauxhall vectra
