Results 1 to 10 of 16
Thread: blanking egr valve
    Regular Member Garfo's Avatar
    plymouth,devon
    Default blanking egr valve
    hi guys
    well just orded the blanking plate for egr my ques is...
    does the egr valve go back on top and plugged back in?
    Aug 2010
    Stoke on Trent
    yep
    plymouth,devon
    Ok cheers m8y :-) also why does it have to be plugged back in ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    It will through up the spanner light - no limp mode. Plugging it back up will put the spanner light out but the emissions light (little yellow engine light symbol) will come on on the bottom right hand corner of the instrument display - not great but more subtle than having the spanner light shining brightly in your face.
    Gazza4
    plymouth,devon
    ok ta very much
    take it engine off while fitting blanking plate?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Quote Originally Posted by Garfo View Post
    ok ta very much
    If you got the small oval blanking plate, then you do not need to remove the EGR, just undo the two bolts holding the exhaust side on, slip in the blank, and refit the bolts - simple as.
    plymouth,devon
    http://cgi.ebay.co.uk/EGR-blanking-p...76471884455608
    Lancashire
    Trim : XP NAV
    As above then.
    plymouth,devon
    oh super
    plymouth,devon
    Need help my egr valve looks round but plate is diff shape ?????
  1. Blanking EGR valve
    By mtqn in forum Engine & Drivetrain
    Last Post: 17th July 2012, 14:11
  2. Blanking Egr Valve
    By Simo87 in forum Diesel Engine related
    Last Post: 31st May 2010, 17:22
  3. Blanking EGR Valve
    By Nav-Man in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2010, 19:31
  4. Blanking off EGR Valve
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2010, 19:12
  5. 120 8v EGR Valve blanking....
    By smiley-sri in forum Diesel Engine related
    Last Post: 14th August 2009, 23:08
blanking egr valve on a signum
