Results 1 to 10 of 24
Thread: Advice
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Advice
    Hi guys, im going to be starting a project at some point (hopefully within the next 6 months). I have decided to convert a corsa to a v6 with a twist.
    The project will be long term as i dont have much time for larking about but i plan to adapt a vectra 2.5 v6 to either a twin turbo or supercharger the thing i want advice on is the revs. Im going to have the cams reprofiled and the cooling upgraded but i want some advice on increasing the rev range. I want the engine to redline at 12k, i know it will require some header work and complete custom exhaust but i want to know what work i will need to perform as i intend to do most of it myself. Also i would like to know about using a diesel fuel pump to maintain pressure at the higher end of the rev range. The pump will be geared to work at optimum pressure for the engine at each rev.
    Thanks in advance
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Did I read that right a 2.5v6 corsa with either twin bines or charger bouncing of the limiter at 12k revs that will be sommit to see! Good luck!
    Jul 2006
    Northampton
    Trim : Sri
    Yes, you did read it right lol. And it will be mid engine rwd its just a plan at the moment but the plan is all set and the work will commence within 6 months. i just need to save some money to buy the engine so i can start work on it. i will be using the turbos from the 2.0 turbo as i want the variable vanes
    Regular Member Jezzy's Avatar
    S.E
    12k? Is it April Fools again already?? What kind of readily available con rods can withstand that speed?
    Jul 2006
    Northampton
    Trim : Sri
    i dont know, thats why i said im planning and wanted advice on getting it to rev that high
    S.E
    Quote Originally Posted by Danwells72 View Post
    I just don't think it can be done in a road car, modified by Joe Public - certainly not with a Vauxhall block and head.
    Jul 2006
    Northampton
    Trim : Sri
    12k may be ambitious but with the right equipment it can be. i wont be doing all the work myself as there are bits that will need to go to specialists and i did say i would be upgrading many components but i wanted to keep the raw elements still vauxhall. This project is not going to be 'over a weekend' but is going to be one of them 'im going to the shed' few year projects due to money and time. i have also thought of using a rwd base and having the engine in the front and gearbox in the back but i like the idea of turning around and seeing a beast of an engine lol.
    Regular Member Exclusive BV's Avatar
    West Midlands
    going at that speed , it will have to be a very well balanced engine not to shake itself apart
    good luck, and when it's built bring it up here and scare the local chavs in their corsas
    Regular Member RhayaderSax's Avatar
    Rhayader
    and when this monster is born how do you plan to transmit all that power to the tarmac as useable traction?
    Jul 2006
    Northampton
    Trim : Sri
    Quote Originally Posted by Exclusive BV View Post
    When its built it will be unveiled at pvs lol
    Quote Originally Posted by RhayaderSax View Post
    Currently it all planning but the power wont be too much to transmit to the floor. i expect around 400(ish) bhp as im planning a bi-turbo setup rather than the traditional twin turbos. i wont be modifying the turbos at all as i plan to use the variable vanes ones. i will be using much wider rear wheels, the drive shafts will have to be custom made and the gearbox will be reworked and strengthened but i have considered using something like the vw dsg box. this part needs more research tho.
    i need to get everything planned before i go to buy the engine and start work. if i dont then i could end up chucking money at it and getting nowhere.
    I would like to rev to 12k but its not an issue if i cant get it there but i still want at least 8k
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
